Scroll Saw Blades
CA
RE: Scroll Saw Blades
Hi,
I use a scroll saw on a frequent basis and have had excellent results using the blades from Mike's. Great price and service. No connection here just a happy customer.
http://www.mikesworkshop.com/blades.htm
I attached a photo of one of my scrap wood projects. I like to build airplanes. Any size or scale.
regards
regards
Your workmanship is excellent. I would venture a guess that if you build flying models, they too would be masterpieces.
My jig saw is probably older than most people that frequent this site. Blades are not available so I take coping saw blades and cut them to length. I try to use a high tooth count for thin plywood.
CA
Dsegal
A few changes in the fuselage layout and this could become a peppper mill. Thanks for the suggestion. Might be time to dig in the scrap box again.
John
Thanks for the kind words. Until recently I have been using a scroll saw that dated back to 1951. It now lives up the street with a new woodworker. I used to make the blades myself by cutting up old 1/16 inch bandsaw blades.
Regards,
John
Regards,
FL
I second Mike's Workshop. He sells excellent blades at a good price. He will send you a few samples for free. These are very fine blades and do break easily so try several and then buy a gross of the ones you like. They run about $25.00/gross which is a good price.
The ones you find locally (lowes, sears, etc) are way too coarse for fine cuts unless all you cut is aircraft plywood.
ORIGINAL: Hydro Junkie
Now John, your saw wasn't made in the 1950's, was it? To be older than some of us, it would have to be
