Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
Zagi Style Wing Dimensions Anyone? >
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 01-27-2003, 04:47 PM
Default Zagi Style Wing Dimensions Anyone?
I am looking for the dimensions for the Zagi style wing. Doesn't have to be Zagi dimensions, just approximate. Has anyone got the templates they can post pictures of? Just finished my foam cutter and want to get started on one of these as well as a Delta wing. Any advice?
Jaymom
Old 01-27-2003, 07:28 PM
I have a friend that might be able to help you with the Zapi information.
[email protected] his name is Eric. Let him know that Chris in Omaha said to get in touch with him.
Chris
Old 01-28-2003, 11:02 PM
Thank you Soarer. I was hoping that someone would post the dimensions but I guess not. Thanks again.
Jaymom
Old 01-29-2003, 12:45 AM
Zagi is 1 ft. root chord 6 in tip chord, 21in span per panel. Thats with 5ins cut off original span to get better roll response. Clark Y with the tail cranked up a bit for reflex would work good. Also tip up the back of the tip template about 1/8 in. for washout, Zagi has a mean tipstall otherwise.
Old 01-29-2003, 12:58 AM
Thanks Gord, appreciate it.
Jaymom
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
