Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
How do I clean the wire from my hot wire bow? >
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 01-30-2003, 03:59 PM
Rahlberg13-delete's Avatar
Default How do I clean the wire from my hot wire bow?
When I cut my foam wings, I get all kinds of crud sticking to the wire. It's a pain to get off. I try to scrape it, but I'm afraid of digging into the wire.
Any ideas how to get it off?
Russ
Old 01-30-2003, 05:29 PM
I use acetone after each cut. Its a lot easier than getting it off after a big build up.
Old 01-30-2003, 05:48 PM
I used to wipe it off every time but don't do that anymore.
I think the easiest way to clean the wire is to string it in your bow, attach the clips to the wire, heat it up and wipe it off. You don't have to heat it up much, just until the goo gets soft.
Kevin
Old 01-30-2003, 11:55 PM
Default gunk
use steel wool
Eric
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
