Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
make your own pusrods?
Old 02-16-2002, 12:22 AM
Default make your own pusrods?
Any ideas on sources for 4/40 pushrod material? That piano wire is too stiff, the hobby shops only sell pre threaded stock and its too small to cut threads. I need a good cheap source.
Old 02-16-2002, 01:35 AM
Mild steel welding rod available at any welding supply place.....
see WWW.rodchuck.com
There is more info here on threading welding rod than you probably want to know!
Old 02-16-2002, 08:42 PM
I made mine out of 3/32" 7071 Aluminum TIG welding wire. The alloy is pretty stiff, but being aluminum, it threads very easily and is very light weight.
Hope this helps...
Old 02-17-2002, 12:04 AM
Get your 4-40, and 5-40 dies from Microfasteners.com, they are cheaper and better quality than RodCkuk IMO.
Vince
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
