Ace Bingo 40
NJ
RE: Ace Bingo 40
Hi Again I did build the 40 size Bingo from an Ace kit..If I remember right the 40 size kit plans didn't have FULL size former parts..I checked with RCM all I see listed is the Bingo 60 size plans..What I'm really trying to do is down size the Bingo to a 46"WS and convert to electric..
Thanks Dan
Thanks Dan
PA
RE: Ace Bingo 40
Why not get the plan for the Bingo 20 which has a wingspan of 49" and area of 440 sq.inches. It can be ordered from Carstens Publications and appeared in the April, 1994 issue of Flying Models. Plan number CF-929, $8.00 + shipping. Go to http://www.flying-models.com/
NJ
RE: Ace Bingo 40
Hi Dave The 49" Bingo plans should be just fine..I will call when they open an order a set..Would you know what the weight of that plane is??
THanks Dan
THanks Dan
NJ
RE: Ace Bingo 40
Hi Dave
I just finished and madeined a down sized 40 Cloud Dancer for electric.It was 25% down sized,from a 60" WS to a 46" WS .I went with all balsa for the formers, mainly replacing all the lite ply..Afterwards I'm thinking that some of the formers should have remain lite ply.
Here is a pic of Electric CD along side the 40 CD..The "e" CD was a little mushy when it was slowed down.I used a APC e 10x5 prop giving me these numbers 32 amps-332 watts..I'm thinking maybe a change in prop may be order..With a APC e 9x6 my numbers were 26amps 299 watts,10x7 40 amps 400 watts..My battery is a 3s4100..What do you think will work best??
Thanks Dan
Thanks Dan
NJ
RE: Ace Bingo 40
Hi Dave I called and the plans are on the way to me..
Thanks Dan
PS with the these plans it saves me alot trouble of downsizing. The original plans didn't have full sacle parts..
Thanks Dan
NJ
RE: Ace Bingo 40
Hi Any one built this plane..I need to know the weight..Mine will be electric..I ordered the
plans, but they couldn't find the weight of the plane..I need to know the weight so I can start looking at E motors for this project..
Thanks Dan
Thanks Dan
NJ
RE: Ace Bingo 40
Hi All the Bingo 20 is coming along just fine..I had the parts cut by http://www.lazer-works.com/.
Got the both wing halves done,just waiting for the wing servo to come in.
The fuselage is rubber banded together and the fit is really great.
Dan
Dan
My Feedback: (82)
OH
RE: Ace Bingo 40
I see the request was made back in Aug,but if your still looking for plans for a bingo -40...I have two kits,and I could loan you a set of plans . You get copies made,or if I can. I could get copies made,but Kinkos is not cheap. Last set I had made cost $20.00... Hope that helps you out.. Good Luck --Joann
NJ
RE: Ace Bingo 40
Hi Jo-Ann I found plans for the Bingo 20, 49" wing span..Check back a few post for the pics..
Wow Kinko's is expensive..I usually go to Office Max or Office Depot, they copy full size plans for only $3.49.
I did build and fly the Bingo 40..I found my plans for ther Bingo, only trouble was the some of the formers weren't full size..
Thanks Dan
Thanks Dan
I sure hope folks haven't stoped following this thread. I am in need of Bingo 40 Plans. I bought Laser cut parts and was going to build it without plans but when I looked things over I realized the plans may be necessary. Any help would be greatly appreciated...
