Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Engine Thrust?
Old 05-01-2003 | 01:23 AM
Default Engine Thrust?
Hi All,
I am very new to RC modelling. I have just had my first flight (lesson) on my recently built Ranger 40 Trainer.
I am also in the process of my first attempt at scratch building. I am building a "Fly baby" to suit .15 motor. My question is;
The plans call for a 1/8 ply sheet engine mount with 4 degrees of thrust (the engine is mounted on its side) I was wondering is it possible to just use a pre fab nylon mount from my LHS? If so what is the best way to obtain the reccommended thrust? Can I just off set the mount to get this? Or would it be better to use wedges under one side of the mount?
Any help would be greatly appreciated.
Old 05-01-2003 | 04:53 AM
This question has been coming up a lot lately. The easiest way is to use washers behind the engine mount to test and when it's flying properly, replace the washers with a wedge sanded from plywood.
Old 05-04-2003 | 11:41 PM
My Feedback: (7)
actually for a minimumal cost of <5.00 ernst has a package of wedges to place behind engine mounts from 1-4 degree sizes just make sure to offset the mount from the centerline of the bulkhead so the crankshaft lines up at the centerline at the prop.
Old 05-04-2003 | 11:45 PM
My Feedback: (7)
by the way the purpose of those seperate 1/8 ply mounts,they were called brakaway mounts back in the 60's.they were designed to break in the event of a crash and save the engine from damage as well as the fuse structure.easy and cheap to replace the 1/8 ply mount than rebuild shattered front end or buy new engine.still a good idea on trainers today.
