Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
RCM FIRESTREAK
Old 04-29-2008, 08:59 AM
Walther
Default RCM FIRESTREAK
I would like to know if anyone here has built the RCM / Joe Mergen FIRESTREAK? I have one that I built in 1982 and never flew because of fuel problems. I would like to try it again if someone could give me some tips.
Old 02-07-2009, 07:47 AM
nicohaas
Default RE: RCM FIRESTREAK
I have a firestreak enlarged to .40 size.
I have the unfinished plane for 25 years and I am working on it now.
ID:	1129314   Click image for larger version
Old 02-07-2009, 08:30 AM
Murdoc
Murdoc's Avatar
That was a nice looking airplane! Is there any plans available?
Old 02-07-2009, 09:11 AM
nicohaas
I think you can buy the original plans
http://www.rcmplans.com/index.php?ma...oducts_id=1693
I have a enlarged model, I bought it partly build and I have no drawings.
gr.
Nico.
Old 02-07-2009, 09:23 AM
Murdoc
Murdoc's Avatar
thanks Just ordered the plan
Old 02-07-2009, 09:35 AM
nicohaas
Mine gets after 28 years probably with two weeks het maiden flight , I keep you informed.
Please do the same.
Old 02-07-2009, 09:43 AM
Murdoc
Murdoc's Avatar
sounds good=) I will do that too.
Old 02-08-2009, 11:50 AM
Walther
Hey! don't forget me I am the one who posted this. Would you like to see a picture of mine?
Old 02-10-2009, 04:35 AM
nicohaas
Sorry, Sorry, your right. i sure like to see you Firestreak.
Mine is sprayed yesterday, I am thinking to electrofy it with a 800 watt brusless and a 5 cell 4000 batterypack.
Old 02-10-2009, 12:11 PM
Walther
ORIGINAL: nicohaas
Did you enlarge the plan or did you buy the enlarged plan that was out?
Electric may be the way to go as a glow engine will not run with the tank location even with a Robart pump. I was told that a Cline PCFS fuel regulator would take care of this but they are $70.0
This is a picture of a picture because I was to lazy to get it out and clean it up!
Tom.
Old 02-11-2009, 06:32 AM
nicohaas
Looks good
Electro has also the advantage of easely changing the rotation direction, you can use normal non-pusher props.
This motor I like to use:Turnigy 50-45 890kv with a 5 cell 5000 lipo.
Has our plane a rudder?
Old 02-11-2009, 07:45 PM
Walther
Nic:
I used mechanical Vtail mixing but with the new radios just mix it with the radio!
Old 02-12-2009, 02:39 AM
nicohaas
ok walther, but is the rudder function effective because of the smal v-angle of the tailplane. And do you have nose wheel controle?
I am also interested in the angle of attack of the landing gear during take off because of the limited rotation possibility because of the prop at the back. I still have to made the landing gear. I don't have a drawing
Old 02-12-2009, 11:08 AM
Walther
Nic;
I don't see that the V tail is a problem but I never flew this model because of the fuel problem. I do have steerable nose wheel but will have to set it up and check the angle of attack, but it is positive. I will also check the length of the gear legs and you can scale them up. The tail should have a skid built into it.
Tom.
Old 02-13-2009, 04:14 PM
nicohaas
Hello,
I am a bit further now, the c.g. is a bit to far I think, It's on the gear now without the (heavy 280 gr motor). So I think electrifien it is the best optien I can then put the batterie (560 gr) in front.
ID:	1134490   Click image for larger version
Old 02-17-2009, 04:19 PM
nicohaas
It is finished now, waiting for the engine.
ID:	1138167   Click image for larger version
Old 02-25-2009, 05:09 AM
nicohaas
motorset arrived. next step is coming
ID:	1144362   Click image for larger version
ID:	1144363   Click image for larger version
Old 02-25-2009, 11:20 AM
Villa
Villa's Avatar
Hi Walther and nicohaas
That is an exciting plane. If you ever want to use a glow engine, you can look up my Building the Spad Canard. It uses an OS46FX engine in pusher configuration. The main fuel tank is in front of the main wing so it too had a fuel problem. I solved the problem by adding a 1 or 2 oz fuel tank just to the front of the engine. I have been flying it that way for about 6 years. No fuel problem.
Old 02-26-2009, 07:23 AM
nicohaas
Just like the small feeder tank at a heli, I did't know that.
too late now I just bought the electroset for this plane.
this has a further advantage for the CG , I can shift with the batterie now , don't have to put lead in it. And I don't need a pusher prop.
Old 02-27-2009, 06:51 AM
Murdoc
Murdoc's Avatar
Looks very nice. When all my current projects are done, I`ll definately build one!
Old 02-27-2009, 10:15 AM
Walther
Murdoc;
let me know if you build the .15 size or if you find the plans for the .40 size. I would be interested in the .40 size plans.
Old 03-01-2009, 05:05 PM
nicohaas
I think there are no .40 plans, you have to blow them up yourself, i'll look if I can find something somewhere.
Here are two pics of my electro configuration
ID:	1147927   Click image for larger version
ID:	1147928   Click image for larger version
Old 03-01-2009, 05:07 PM
nicohaas
Here some data
66 amp
1100 watt
11000 rpm with a 11*7,5 graupner.
Old 03-01-2009, 05:50 PM
Murdoc
Murdoc's Avatar
ORIGINAL: Walther
Murdoc;
Will do I`m going to build the 15 size first, and then enlarge the plans so it will fly with a 70 4stroke.
Old 03-11-2009, 10:13 AM
nicohaas
Made the maiden flight last saterday.
Flight caracteristics are very good. Power is far enough. Rotation angle at the concrete runway was good.
After take off you can power down imediatly.
But.... In the landing things went wrong, I had a 30 degree crosswind and because of the big vertical tail surface it was difficult to line up.
I made a crash landing beside of the runway.
Landing gear brok out and the vertical fin broke in pieces.
I'am reparing it now.
ID:	1155216   Click image for larger version
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
