Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Problem with Ulitmate Bipe
Old 05-18-2003 | 01:07 AM
Default Problem with Ulitmate Bipe
I have recently finished building a Great Planes 40 size Ultimate Biplane. I test flew it earlier today and I am lucky to still have it in one piece. After rolling into a right bank, the plane rolls left and pops up when I apply elevator. I don't know what it does when in a left bank and elevator is applied, I didn't get that far. I think that the elevators aren't aligned, but I really don't know. Any suggestions would be helpful.
Old 05-18-2003 | 02:55 AM
Bipe Flyer's Avatar
It sounds like your elevators aren't moving the same amount. It could also be a twisted wing, too much elevator travel, accidental mixing of the rudder or ailerons with the elevator or it cold be tail heavy.
Old 05-31-2003 | 01:43 PM
Hisham's Avatar
What engine are you powering this bipe with???
Old 06-03-2003 | 02:27 PM
check engine thrust alignment, you need 3 degrees of right thrust for an Ultimate in my experience
