Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
Reload this Page >
F-22 Raptor thrust vectoring scratch built twin ducted fan jet
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 06-15-2009, 12:26 PM
MikeysRC.com
Default F-22 Raptor thrust vectoring scratch built twin ducted fan jet
I just threw this together a few days ago. Pretty fast with good vertical performance. Only uses two servos. Each servo is connected to an aileron and taileron.
FREE PDF plans for this jet will be available in the near future from
www.mikeysrc.com
http://www.youtube.com/watch?v=WDNLNAYjFVE
The jet uses;
Twin GWS 64mm EDF units
2 4400kv brushless motors from hobbycity
2 9 gram TowerPro servos from hobbycity
2 40 amp ESC speed controllers from hobbycity
Ideal battery is 2 1300mAh 20 11.1V batteries. BUT 1250mAh - 1800mAh also worked.
Flight times range between 5-7 minuets depending on ho much of a speed freak you are =)
"Mikey"
ID:	1218718   Click image for larger version
ID:	1218719   Click image for larger version
ID:	1218720   Click image for larger version
Old 01-28-2020, 12:42 PM
Tom410
hey I'd love to get a copy of your plans if you still have them
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
