Hughes H-1 1/4 scale
#259
Thank you all for your kind words.
After the maiden flight I found that I had made a terrible mistake with the angle of attack of the wing.
It was set up at 0 degrees and it was the reason that the plane had a nose heavy feeling. I thing that the long tail saved it.
Anyway, the H-1 is back on the bench and is under surgery to correct the angle of attack to 2 degrees.
@ RC Technics the plans are from VTH.de the cowl is hand made by me, check post#118
