engine size
56.5" X 11.125" chord X 15.5%airfoil, 49" nose totail, 18-20 oz. wing load..... given those parameters, would a .46 be enough for enjoyable, "easy-does-it" flying?
RE: engine size
Yes
Copied from http://adamone.rchomepage.com/design.htm Recommended Engine Size vs Wing Area c. in. area sq. in. .049 200 - 250 .10 250 - 350 .15 300 - 450 .25 400 - 500 .40 500 - 700 .60 600 - 850 "Powered model aircraft performance may also be estimated by calculating the weight / power ratio, also known as power loading. A slow and low wing loading (for a beginner), with a weight / power ratio of 440 to 500g/c.c. (270 to 300oz/c.in.) might be good enough, whereas an aerobatics would need about 340g/c.c. (200oz/c.in.) to achieve good performance. This is assuming 2-stroke engines and that the power of different types is pro- portional to their displacements, (which isn't too far off)." |
RE: engine size
thanks again, Lnewqban....
this is for that same plane. when i blew the prints up, i studied as many specs as as could find to come up with a suitable expansion number. as it is getting nearer the covering stage, i find myself questioning it's weight because it's it seems to me that it's got a good bit of wood in it. i've seen most of the spread sheets dealing with weight, size, volume, etc and engine size, i just wanted to run by you guys with more building experience. funny thing happens as you get older..... you realize you don't know everything and discover it's not a bad thing to refer to experienced knowledge!!. you've been helpful, ron. |
| All times are GMT -8. The time now is 01:26 PM. |
