design questions
1 Attachment(s)
I am designing a Skyvan and I'm trying to make it as close to scale as I can. My question is should I use the real airfoil or should I use one that is more suited for RC?
I can't find what airfoil is used on the real plane. Thanks in advance Bill http://www.rcuniverse.com/forum/atta...mentid=2068220 |
You are always better off using an airfoil that has been proven successful for model airplane use than any of the full size airfoils. The two are unrelated. I have used the NACA 2415, 2417 and 2419 over the years for all of my models. Compufoil software is excellent for this. Dan.
Originally Posted by All Day Dan
(Post 11970370)
Mark |
It seems that the full size Skyvan uses NACA 63A414
http://m-selig.ae.illinois.edu/ads/aircraft.html What size is the Skyvan model? |
I like the NACA 23XX airfoils vs the 24XX because the high and low point of the airfoil are both at 30%. Makes for ideal D tube construction.
Chuck |
@ perttime I have it laid out both at 81" and 90" wing spans.
@ R8893 can you be explain D tube more? |
wildwillie,
A "D" tube refers to the end view of an airfoil where the leading edge is sheeted back to the top and bottom spar and there are shear webs between the spars. The outline looks like a stretched out capital letter "D". Pretty common design for models. You'll get the most strength out of a spar if it is at the thickest point of the airfoil. Chuck |
Oh ok, I know what you mean now.
Thanks |
Does anyone have a recomendation for power (motor size)? I would like to go with electric.
Bill |
3 Attachment(s)
It's an easy build and a fun flyer. Two here are electric. 62" span.
1 Attachment(s)
Here's my plan.
Very Cool! Rich
Originally Posted by wildwillie3
(Post 11971227)
Bill You'll find that at 55'ish watts per pound that the model will fly in a scale like manner. At 70 watts per lb it'll fly like a WWII fighter or hot modern private plane. More than 80 watts per lb and you're verging on jet fighter territory. At 100 watts per lb it will be very close to unlimited vertical climbing. |
Thanks for the guide lines for power, I guess I will just leave space on the firewalls for larger motors if needed. I do plan on using it for payload.
Bill |
