Looking for trainer plans
I am looking for a 60 sized trainer plans. I have the RCM but they are only 40 sized. I have the Kadet, Senorita, telemaster too. What I am looking for is something like the PT 60. I have looked but have not found it yet.
Thanks. Buzz. |
Hi Buzz,
You can take 40 size plans and scale them up. For a reference how much to scale up, you can find similar plane in 60 size and copy the size of the wingspan. |
I was thinking of just blowing up the PT 40 plans to the 71 inch span and see what I can come up with.
Buzz. |
My buddy had a PT 40..we called it "The Flying Four by Four"
Made a decent float plane with enough power... If you can't find the plans here http://www.outerzone.co.uk/index.asp I bet you can find a 100 other interesting trainers or vintage planes that tempt you ! |
Yes I have spent hours and hours looking at all the good stuff on Outerzone. If I lived a thousand years and had boat loads of balsa I could not build them all. Reason I was looking at the PT 60 was the simplicity. Could be cut and framed in a weekend easy. I may just break down and get the kit.
I do have a nice Quaker Flash to build. Big, old, slow flyer. Buzz. |
i have the rcm plans for 60 engines if you like i send to you in pdf format
| All times are GMT -8. The time now is 03:42 PM. |
