HELP ??
Can anyone tell where the balance point on a bipe should be ? It is a big bingo that I fitted two wings from a sig cap arf to. The top wing is 1" forword from the lower wing. I dont know if it should balance on the spar of top wing or father back? Thanks
RE: HELP ??
Looking at from the top, measure from the leading edge of the top wing, to the trailing edg eof the bottom wing, and measure 30% of that. In other words, if the lower wing is 1 in. back, add 1. in to the top wing chord, and figure 30% of that. Should put you in a safe ballpark to start from.
| All times are GMT -8. The time now is 08:42 PM. |
