40 size cub
I was wondering if anyone had any plans for a 40 size cub that they might be willing to share. I downloaded one set of plans, but many of the dimensional marking are missing, and I cannot quite tell for sure what size it is supposed to be, the wingspan is about 70 inches.
The plans I have came from www.aviationshoppe.com The file is J3cub1.zip Any help would be appreciated. Thanks, Jacob |
RE: 40 size cub
Jacob-
Just pick up whatever dimensions you need from the CAD program you're using. The dxf file is already set up to "full scale" for the model, or about 1/6 scale of the full-size Cub. If you'd just as soon build from a kit, I heartily recommend SIG's 1/6 scale Cub, although I did laminate the tips (like the plans file you mentioned) instead of using their die-crunched tip outlines. I fly mine with wheels or floats with a OS FS26 4-stroke. -Dave |
