RCU Forums
-   Scratch Building, Aircraft Design, 3D/CAD (https://www.rcuniverse.com/forum/scratch-building-aircraft-design-3d-cad-174/)
-   -   problem insert DXF in drawings (https://www.rcuniverse.com/forum/scratch-building-aircraft-design-3d-cad-174/4646904-problem-insert-dxf-drawings.html)
sergio luiz 08-20-2006 03:06 PM
Hi Guys,
Somebody can tell me because a file generated in the program WINFOIL in DXF with measures in inches, when enclosed in the drawing that this in inches also
Is the size of DXF much larger than the one of the drawing?
And how should I do for this to solve?
Thank you for the attention
Sergio Luiz (JOCA)
aerowoof 08-20-2006 03:50 PM
RE: problem insert DXF in drawings
a dxf file should open at the size it was originally drawn in.in design cad there are two option.you can use units to define the new size or scale which you have to but in a scaling factor for both x and y axis.other programs should have similar commands for sizing.
dolanosa 08-20-2006 11:04 PM
Sorry but I do not use Winfoil. Some applications will make the airfoil to 1 unit in chord. Meaning it could either be in 1 unit of metric or in US foot or inches. This, of course directly reflects on the coordinates of the airfoil. Basically, you just need to set up your CAD application to use whatever units you want and scale accordingly. Hope this helps.
