60" Scratch Telemaster Stabilizer question
Yep, 60". I decided to scratch build one midway between the Mini and Electro versions HL offers. Plans and a build log will be on my website, airplanenut.net.
My only hanging question about the build is: Should I use a flat horizontal stabilizer like the Mini and Micro Telemasters? Or should I use a lifting stab like the larger Telemasters? |
RE: 60" Scratch Telemaster Stabilizer question
I built one about that size many years ago. I used a flat stab and was always disappointed with the airplane. I never thought it flew like a Telemaster. I did have a 6' version to compare.
Jim |
shouldn't make any difference in normal flight characteristic's. unless your trying to Hot Dog it. all of mine up to 80" flew super with flat stab. dick
Hi Dfalcon
I agree that it probably won't make much difference whether you use a flat or lifting tailplane. There used to be a 66" version of the Telemaster avaiable in Europe about twenty years ago. It had a lite-ply fuselage. I got my "wings" on one! It had a lifting tailplane. The British Keil Kraft Super 60 wich is about the same size and type as the model you are building, originally had a built-up symmetrical tail but this was later replaced by a flat tailplane made from 1/4ins square balsa. Both flew well. I've even heard of people building them with the tailplane made from 1/4ins sheet. As they say over here: "You pays your money and takes your choice." Happy Landings David Davis |
