Go Back  RCU Forums > RC Airplanes > Seaplanes
Reload this Page >
Northstar paint scheme : post your pix !
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Old 09-20-2003, 04:47 PM
Strykaas
Default Northstar paint scheme : post your pix !
Hi
I'm looking for a good paint scheme for this aircraft .
Could u plz post your pix here ?
Thanks !
Old 09-22-2003, 03:00 PM
dr_wogz
Default RE: Northstar paint scheme : post your pix !
Here's mine...
Old 09-22-2003, 03:44 PM
Strykaas
Thanks !
What finishing method did u use ? Retractable film ? Paint ?
Old 09-24-2003, 10:11 AM
dr_wogz
Salut!
Non, c'etais tous 'Monokote'. beaucoup des morceaux!
Old 09-24-2003, 01:56 PM
MinnFlyer
MinnFlyer's Avatar
Beam me up Scotty, I think the Universal Translator is malfuntioning.
Old 09-24-2003, 04:43 PM
Strykaas
Monokote is a retractable film ... Isn't this a problem for an aircraft actually evolving in water ?
Old 09-24-2003, 05:28 PM
Neo02
Neo02's Avatar
Hi Strykaas,
no, Oracover and Monokote do not have big problems in water, except when the edges are not ironed on carefully.
As an added security, I let a little drop of fluid CA run through all edges of the plane (leading and trailing edge, floats, fuselage...), this helps sealing all open parts and prevents water from reaching the balsa underneath. Put a small drop of CA and let gravity do the rest!!
Contact me if it's not clear enough, I will try to post some pictures :-)
Regards,
-Fabrizio
Old 09-25-2003, 04:05 AM
Strykaas
Actually I've thought about using Oracover that I'm going to paint comletely with polyurethan stuff. What do u think ?
Old 09-26-2003, 02:50 PM
Goinstraightup
My Feedback: (26)
Goinstraightup's Avatar
I think the paint is not needed. I have a Sea Cruiser II flying boat that I covered with Ultracote (same thing as Oracover) and have not had any problems with water getting in under the covering. I did not do anything to seal my covering seams, but you can use the CyA tip if you want.
Old 09-26-2003, 04:49 PM
Strykaas
Is CA Cyano Acrylate ?
Old 10-08-2011, 01:22 PM
Strykaas
Bump !
Old 10-08-2011, 02:49 PM
Lamoilleriver
CA is California,
Old 10-08-2011, 04:14 PM
Goinstraightup
My Feedback: (26)
You didn't cover that plane yet??? [X(][8D]
