That sinking feeling.....1/4 scale floats leak!!
My Feedback: (9)
MD
I bought a pair of Hangar 9 floats just before they were discontinued, finally got around to attaching them to my 1/4 scale Hangar 9 J-3 Cub. Took it to my pond to do a float test and they failed! Both sides leak! After the first test I took the plane back to my shop and sealed the rudder to float attachment with J-B Weld and looked for and sealed any and all pin holes I found on the bottoms. Took back to the pond and failed again. There must be a hair line crack in a seam somewhere. Looking for suggestions.
No the floats were not dropped or struck by any object,,,fresh out of the box and onto the plane.
Had a set of floats that did the same thing and everything we tried to seal them eventually failed again as the seams/cracks opened up. What finally worked was to fill them with expanding foam. We found a two part mix used for floatation in boats. You have to be careful not to use to much as the expansion of the foam will distort the float. We cut a few one inch holes along the top of the float then mixed up small amounts of the two part foam and poured it inside. The expanding foam filled the float a bit at a time as we did it in stages. The foam as well as filling the floats also glued everything together. These floats are still in use several years later. I suppose one could use the spray in insulation foam if one was careful. I even bet the polyurethane glues like gorilla glue and a spritz of water would expand and stick the floats together likewise.
PS the foam has to be closed cell so it does not absorb any water.
Dennis
Dennis
My Feedback: (9)
MD
Dennis
Dennis
