Go Back  RCU Forums > RC Airplanes > Seaplanes
Reload this Page >
.40 size floats, how wide?
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Old 01-15-2005, 09:57 AM
FlyerBry
My Feedback: (8)
FlyerBry's Avatar
Default .40 size floats, how wide?
Hi all,
I am considering building some floats for may .40 size GP Cub. In looking at the commericially produced floats it seems most run in length from 33 to 36 inches for a .40 size plane. I don't, however, see any widths listed with these floats. How wide should I make each float? Anyone have any simple plans or dimensions for what I am trying to put together that may help me out?
Thanks!
FlyerBry
Old 01-15-2005, 12:46 PM
JimCasey
JimCasey's Avatar
Default RE: .40 size floats, how wide?
It's easier to cover them if you limit the top to 2 3/4 inches, because that's the width you can count on from a sheet of balsa. Then taper the sides and the bottom (planing) surface is wider......surface area where you need it. These tend to run around 5 inches wide.
If you have any drafting skills you can scale this. Everything in these floats should be balsa except the bottom in front of the step can be ply if you are reluctant to fiberglass, and reinforce the mounting points with ply as well. WATERPROOF THE INSIDE because floats have a nasty habit of storing water and turning into a pretty icky science project...
Old 01-15-2005, 06:37 PM
FlyerBry
My Feedback: (8)
FlyerBry's Avatar
Thanks Jim,
That is a very nice looking plan. Very scale looking!
FlyerBry
