Go Back  RCU Forums > RC Airplanes > Seaplanes
 Bernard Dumas' Canadair CL-215 >
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Old 12-14-2007, 11:21 AM
  #301
g_boxwood's Avatar
Default RE: Bernard Dumas' Canadair CL-215
I think this will be the last update of the year... I'll then have to stop and get back to the books for my final run to the degree...
Basically I decided to seal the rudder TE as I did with the stab: a thin home-made fiberglass foil that is forced in place while the epoxy cures; it is easier with constant thickness airfoils while it took me a little more effort with the rudder...
Next I had to re-open the gudgeon slots into the TE...
... and I finally epoxied the guds in place checking for straightness of the hinge-line itself!
Old 12-14-2007, 11:33 AM
  #302
g_boxwood's Avatar
I thought I could give the HS-85MG a little help by installing functional trim tabs (in this case, boost tabs): I placed them in some of my models (sport) and they prooved really effective.
I took as a guide an informative article in Model Airplane News, December 1993 if I recall correctly: if someone is interested just let me know and I'll gather some more infos.
Anyway, everything started by attacking the rudder and cutting the tabs off:
Next I added a 4mm LE block to the tabs and worked a little more on the upper tab: the upper tab extends past the rudder TE so it needs a TE extension. The following pic shows what I did (top to bottom):
1. I took the homemade fiberglass foil and glued it to one side with medium CA
2. I added some balsa sheet of appropriate thickness
3. I sanded it to shape
4. I filled everything
Once satisfied with it I sanded the LEs to their round shape and I checked the tabs over the plans:
They look both scale and functional!
Old 12-14-2007, 01:04 PM
  #303
hello Giacomo
as always it's a verry good job
Phil
Old 12-14-2007, 11:08 PM
  #304
My Feedback: (24)
Kmot's Avatar
ORIGINAL: g_boxwood
I took some pictures of my ship-wreck-workshop as it was today
Well now, I see you are indeed human after all!!
Have a Merry Christmas Giacomo, and a great New Year!
Ciao
Old 12-24-2007, 06:46 AM
  #305
g_boxwood's Avatar
Thank you all for having supported this thread for 2 years now and nearly 30,000 hits!!!
I wish you all the best for the upcoming 2008 and may all of your dreams and projects come true!
Thank you all again!
Giacomo
Old 01-04-2008, 09:27 PM
  #306
teresos's Avatar
Happy new Year to all of you guys.
Giacomo , your work is magnificent .
I finally got then Nose Gear done [sm=thumbs_up.gif]...
with :
Sreering (with ball-rings)
Shock-absorbing
Retract mechanism......and it's working great.
Shots 1 to 3 was my first attempt with cardboart ,
shot 4 is the first drawing with pencil ,
shot 5-6 are the final drawings and dimensions finished with Corel ( I can't .....CAD. )
Old 01-04-2008, 09:49 PM
  #307
teresos's Avatar
oooooopsss.....
ID:	842411   Click image for larger version
ID:	842412   Click image for larger version
ID:	842413   Click image for larger version
ID:	842414   Click image for larger version
ID:	842415   Click image for larger version
Old 01-04-2008, 09:54 PM
  #308
teresos's Avatar
Here are some shots from the Gear :
ID:	842423   Click image for larger version
ID:	842424   Click image for larger version
ID:	842425   Click image for larger version
ID:	842426   Click image for larger version
ID:	842427   Click image for larger version
ID:	842428   Click image for larger version
ID:	842429   Click image for larger version
Old 01-04-2008, 10:18 PM
  #309
teresos's Avatar
Some shots during the process :
ID:	842455   Click image for larger version
ID:	842456   Click image for larger version
ID:	842457   Click image for larger version
ID:	842458   Click image for larger version
ID:	842459   Click image for larger version
ID:	842460   Click image for larger version
ID:	842461   Click image for larger version
Old 01-04-2008, 10:28 PM
  #310
teresos's Avatar
some more..
ID:	842467   Click image for larger version
ID:	842468   Click image for larger version
ID:	842469   Click image for larger version
ID:	842470   Click image for larger version
ID:	842471   Click image for larger version
ID:	842472   Click image for larger version
ID:	842473   Click image for larger version
Old 01-04-2008, 10:45 PM
  #311
teresos's Avatar
I can mail the drawings to everyone...( crazy like me [sm=bananahead.gif] ) ....
ID:	842490   Click image for larger version
ID:	842491   Click image for larger version
ID:	842492   Click image for larger version
ID:	842493   Click image for larger version
ID:	842494   Click image for larger version
ID:	842495   Click image for larger version
ID:	842496   Click image for larger version
Old 01-04-2008, 11:18 PM
  #312
My Feedback: (24)
Kmot's Avatar
teresos: Bravo!! Magnificent!! [sm=thumbup.gif][sm=thumbup.gif]
I love how you did this on a manual machine.
Old 01-05-2008, 04:11 AM
  #313
g_boxwood's Avatar
Great George! I want one! Machine one for me!
Really great work, I can CAD your drawings if you wish.
Old 01-05-2008, 06:35 AM
  #314
Thats IS scratch building. Love it
Old 01-09-2008, 05:02 PM
  #315
to place photography of the construction of the wings.
greetings thank you
I'm sorry for my English that is very bad
Old 01-12-2008, 03:34 AM
  #316
g_boxwood's Avatar
You could check some earlier pages: there are pictures of a finished wing by teresos (George) and there are 3D renderings of my upcoming wing!
For more detailed pics you should ask teresos as he is the only one who has already built one.
Old 01-12-2008, 12:06 PM
  #317
Excellent idea, what kind of metal- tools are using to make it ?
Old 01-12-2008, 09:49 PM
  #318
teresos's Avatar
ORIGINAL: coincoin
Welcome on board coincoin...
Einhell Metal Lathe MTB 3000 (classic Chinese 7x12 mini lathe )
Proxxon Micro Mill Mf 70
Einhell Pillar drill
Dremel moto tool
lot of hand tools
http://www.einhell.com/englisch/englisch.aspx?file=car
http://www.proxxon.com/
http://www.dremel.com/en-US/tools/
Old 01-18-2008, 08:47 AM
  #319
teresos's Avatar
Giacomo ,
have you done anything about the nose door hinges. I'm trying to figure how to deal with.
Have you got any ideas?
George
Old 01-18-2008, 09:14 AM
  #320
thank you I already saw them but they do not say to me as it was the construction
Old 01-18-2008, 10:02 AM
  #321
g_boxwood's Avatar
ORIGINAL: teresos
Giacomo ,
George
No, especially now that I'm reconsidering my nose unit beacuse of your great work.
Anyway, it shouldn't be a problem, just use the offset type of hinges that are common with jet models. And I suggest you build thick doors not fiberglass-thin ones: the thicker they are the better they seal.
Please bear in mind that the nose well doors don't need to be water-tight EVEN in case of amphibious operation: the wheel well must be water-tight but not the doors. They should not allow too much water in...
The doors should deflect the fluid away from the bulkhead: if the fluid itself hits the bulkhead it will slow the plane down and it will prevent it from getting on step and leave the water.
I hope I got myself explained...
The only thing I did was a mold of the hull around the well opening:
As you see from the last pic my well is longer to fit the commercial retract unit: if I fit your gear I will shorten it back to its original length!
Old 01-18-2008, 05:16 PM
  #322
teresos's Avatar
[/quote]
Yes I know , that's why I build them from lite-ply.
You are right about the commercial hinges.I have something in mind, but still it need's
work.(... Yes ,a try $ fit proccess again....[sm=72_72.gif]......) .I let you know when I'm finished, so
you will CAD for me , again!!!!!
ID:	854340   Click image for larger version
ID:	854341   Click image for larger version
Old 01-19-2008, 03:39 AM
  #323
g_boxwood's Avatar
No problem at all!
Old 01-27-2008, 09:57 AM
  #324
g_boxwood's Avatar
Tip-Float Molding - Making the Parts
Hello everyone, I took a break from studying to mold my first halves and see how they turned out...
First let me say that making the parts involves a fraction of the time and effort we spent for making the molds themselves BUT you need to exercise care while handling the molds to avoid damaging them during any of the procedures involved.
0. Getting the molds ready
It happened that the PVA got stuck to the molds instead of the plugs: do not worry, PVA is easily removed with fresh water and some soap (dish-washing is fine). Wash and clean the molds throughly under the tap; a smooth sponge may help removing all the PVA from corners and sharper features.
I then mounted the molds onto some MDF framing: I covered the frame with some heat-shrinking covering material so the resin won't get stuck to it (fast and easy).
1. Waxing the Molds
I wanted to avoid what happened to the plugs so I invested a lot of time in waxing the molds properly. I understood 2 important issues:
1. an epoxy-resin mold is a more chemically stable material on its own than a painted plug: its surfaces are harder and "glossier" than "the glossiest" of one-part paints!
2. polishing is not necessary BUT if you intend to polish the molds use a silicon-free polishing compound or it will be hard the get the wax to wet the molds properly.
Obviously I did use a silicon-based polishing compound and I ended up fighting with the wax again... but at least I now know why!!!
I used a waxing compoud called 'Priming Wax': they claim it features superior 'wetting' properties and that it helps the PVA to spread in a more uniform layer, plus it doesn't need any polishing (=buffing to a good shine) between coats.
It is not the best wax available but it is suggested for beginners!
SO, I gave 5 coats of Priming Wax @ 24 hrs. intervals + 2 coats of PVA @ 24 hrs. intervals. I then let the PVA dry for another 24 hrs. before molding.
Picture shows the molds ready:
2. Homemade Gel-Coat Layer = 1st resin batch
I started with a ketchup-thick mixture of (resin+hardener + grey colour paste + microballoons) and I painted it onto the mold surfaces keeping the layer thin; please remember:
1. this layer fills the cloth
2. this layer should stay onto vertical surfaces in a thin layer (the thicker the more mass the more difficult to prevent it from running down on its own weight)
3. this layer should avoid trapping air bubbles <=> its thickness should be less than the radius of the bubbles themselves
4. color selection between molds and layer should enhance the contrast so that you know where you painted it and where you didn't (and it should help you determine its thickness at a glance)
Now thicken the mixture with more balloons and smooth all the tight-radius corners so that the cloth will conform to them more easily:
Now let this layer gelify to a state where it will be 'tacky' (if you press a finger into it NO resin should remain onto your finger): it usually takes 45 minutes but it depends strongly on many parameters so check every 15 minutes: it took about 2 hours in my case.
Old 01-27-2008, 10:10 AM
  #325
g_boxwood's Avatar
3. Cloth Lay-Up = 2nd Resin Batch
I chose to lay 4 layers of cloth: the first 2 should be light so they conform to the mold while the other 2 could be heavier BUT open-weave (not tight).
Paint the mold with a liberal amount of resin and then start working each cloth layer in place so that no bubbles get trapped in!
work each layer at a time, remove all the bubbles and wrinkles from it before adding the next one. Easier done than said...
Once all the layers are in place remove the excess resin and let the epoxy cure overnight:
4. De-molding
I was surprised by how easily I got the parts away from the molds: I used some PP wedges and I worked them around the perimeter of the parts...
... until they popped out on their own:
I then trimmed them roughly... and I got back studying satisfied with the results!
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
