E-Flite Taylorcraft 450 on Floats
TX
Finally got around to this project. As those of you who are into scale electrics already know this little ARF is a great flying model as it comes out of the box. I liked it so much I decided to try it as a float plane. I used 24" flat-bottom foam floats from Seaplane Supply <www.seaplanesupply.com>. No financial interest; I just decided to try their product. I used a Park 450 outrunner and 22 Amp ESC with a 2,000 mAH 12c 3s1p LiPo. Plenty of power on a 10x7 APC SF prop. Bottom of the floats was covered with clear mylar packaging tape in the interest of keeping them light. Painted the exposed foam with water based spray paint to seal it up.
The T'craft has a semi-symmetrical wing so I set the wing to float incidence at 3.5* positive. Once it's on the step it will fly itself off the water with just a touch of up elevator. Here are some pics:
TX
ORIGINAL: jpg0529
Nice Charley!
I have a buddy that flys one here in Maine and it seems to be a great float plane.
Joe
Nice Charley!
Joe
CR
BC, CANADA
I always wanted to try this... Saw the Taylor Craft when it first came out and thought "Hummmm"... But looks like you beat me to it Charley
... I don't have enough space for another plane... Good job... Who knows maybe I'll be able to squeeze one more into the basement...
FL
Not that I'm inpatient but I ordered my Taylercraft 1/30/08 and it is still on backorder. No one seems to have any. I happen to be 82years young but don't know if I'll still be here when it arrives ???
TX
ORIGINAL: TedMo
Not that I'm inpatient but I ordered my Taylorcraft 1/30/08 and it is still on backorder. No one seems to have any. I happen to be 82years young but don't know if I'll still be here when it arrives ???
The model is worth the effort. It really flies well.
CR
BC, CANADA
ORIGINAL: Jollidude
Darren, you have to stop building those huge seaplanes!
Cheers!
Jollidude
Cheers!
Jollidude
I here Yah.. you old timers
TX
ORIGINAL: TedMo
CR
What paint did you use and where did you get it. I have the same floats for the same airplane and want to finish them as light as possible. Im using balsa for the bottoms though. Will the paint seal balsa as well. The dealer says to use polyurethane paint, but noone has it.
TX
ORIGINAL: walrath596
CR
Is the krylon H20 totaly foam safe or did you have to spray from a distance? Do they make it in silver? How many coats did you do? I was thinking of covering in .5oz glass, do you think this would be too heavy for the plane? Does the krylon paint make them strong enough or are they farely delicate? Thanks!
My Feedback: (71)
CA
Here's the maiden flight of my TC on floats. I'm still working the bugs out, but it pops off the water and flys great! Thanks to Charlie for the help with the float set up!
http://www.soaringunionoflosangeles....ftonFloats.wmv
TX
Lookin' good, Barry! The way she comes off the water is real nice. You must have the incidences right. Congrats! Glad I could help.
Er, was that one landing or three?
CR
CR
My Feedback: (71)
CA
Charley: thanks again for the help. Yeah, the pucker factor was really high
and I skipped her a bit on landing. It's such a light plane and I really need to fly it on to the water VS cutting the throttle and flaring. I made 3 approaches and just decided to go for it. At least I didn't panic and tip stall her after the first bounce!
I was really surprised at how nimble the plane is with the floats, I tried to rip the wings off, but no such luck. I had over 100 flights on my last TC (may she rest in pieces) and it's a great flying little plane. BTW, you were right about needing a water rudder on this plane, it weather vanes very easily. I am going to increase the size of the water rudder before the next float fly. I kept it small in the hopes of keeping the weight down, but it really needs more authority to taxi in a breeze.
TX
ORIGINAL: Mojavegold
BTW, your video was herky-jerky in Win Media Player but played fine in Media Player Classic. Wonder if I'm the only one who experienced that. (??)
Congrats again,
CR
ID
Here is yet another Eflite T-craft 450 with floats. Thanks to Charley for blazing the trail and pointing us to www.seaplanesupply.com for the floats.
Eflite 480/1020kw motor. 10-7 prop
Eflite 40 amp Pro switch-mode bec controller
Thunder power 2200mah 25c 3 cell lipo
Spektrum rx and 4 7.5 gram Spektrum servos
Seaplane supply 28" flat bottom floats, style #2(I'd get syle #1 or #3 if I had it to do over again, just easier to mount), square step. Floats have light weight fiberglass on the bottoms, thinned light spackle skim coat, and Nelson Hobby water based polyu paint.
Flys great at our 2800 foot elevation. I think it flys better with the floats than with the wheels....
The ducks seemed to like it too!!
Randy
Randy
TX
Hey man,
That's just great! The fibreglasse and paint add to the database of "what works." That's what makes these forums such a great idea.
b CR
b CR
TX
Looks great!
Gets off good too, I gather. Wasn't much wind, huh? Get some water rudders on it or you better always be downwind of the recovery area.
CR
CR
