Go Back  RCU Forums > RC Airplanes > Seaplanes
Reload this Page >
Discussion - Tony Nijhuis Sunderland
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Old 07-21-2008, 03:12 PM
siddus74
siddus74's Avatar
Default Discussion - Tony Nijhuis Sunderland
Guys have any of you seen the new offering from Tony Nijhuis? I was lucky enough to see it @ the recent LMA Cosfrod show. The eletric 72" Sunderland, I have purchased a short kit looks of good quality . . .
[link=http://www.modelflying.co.uk/news/article/mps/uan/331]Article[/link]
Any takers on this one?
Old 10-04-2008, 05:42 PM
Fast Freddy
Default RE: Discussion - Tony Nijhuis Sunderland
Yup, have seen it on Tony's webpage and it states the model, short kit, plan will be available sometime in the winter of 2008. Will have to keep my eyes open for this one. Looks great!!
Old 10-05-2008, 03:12 AM
Fast Freddy
The other thing I like about this design is that it's electric and it's not gigantic. At 72" it's big, but not so much so that transportation and storage becomes an issue. I can hardly wait for this bird!
Old 10-05-2008, 05:16 AM
siddus74
siddus74's Avatar
I have both the plan pack and the wood pack, the plans are of excellent quality . . . I have also bought a SLEC building jig for this projetc as well.
One thing that is missing for me at the moment is motivation after building the Catalina and Canadair I am all built out for the time being. I keep getting the plans out and putting them away.
I think I would have to build a twin wing first with a couple of .25's and if that panned out build a second wing with 2 x .15's and 2x.10's
I think as an electric it would be fab, but have to charge up 4 batteries for a single flight, what a drama.
Old 10-05-2008, 11:03 AM
Fast Freddy
Siddus74,
My guess is you obtained the plans and kit from a show / event in the UK? Living in the US I'll probably have to wait for the RCM&E article and watch Tony's website for future updates. Lucky you!
An idea: On the battery issue, I would consider investing in 2-3 Lipo batteries that will give you 15-20 minute flights. Expensive yes, but much more reliable when running 4 electric motors compared to 4 glow engines.
Old 10-05-2008, 08:44 PM
Lake Flyer
My Feedback: (13)
Any idea what issue of RCM&E it will be in? Does Tony Nijhuis have a website and does anyone have the address for tony's website?
Old 10-06-2008, 10:11 AM
Wayne22
Wayne22's Avatar
Too bad it is so small and not piston powered....
Old 10-06-2008, 04:27 PM
Fast Freddy
Tony's website: www.tonynijhuisdesigns.co.uk/
RCM&E website: www.modelflying.co.uk/ Fantastic magazine, a bit pricey at $60/year in the states, but a free plan every month!
No indication as to what issue the Sunderland will be posted in or when plans, kits and/or parts will become available.
Keep checking and stay tuned!
Old 10-08-2008, 01:29 PM
ssmiff
Why not send an e-mail to '[email protected]' as they are the ones producing the kit.It was there marquee that the original picture was taken in I saw it at the UK nationals but bought a schneider S6B planpack instead.
Old 10-22-2008, 03:55 AM
siddus74
siddus74's Avatar
Finally got some motivation to build my slec jig and start my Sunderland. A mate came around and we built the basic structure of the hull (thanks Simon). The lite ply stuff is of relatively poor quality and none of the formers were straight which made the hull alignment really difficult, I wished I had only purchased the plans and woodpack now not the laser cut stuff. I always find light ply dodgy.
7 hours work gives only small reward!
ID:	1056788   Click image for larger version
ID:	1056789   Click image for larger version
ID:	1056790   Click image for larger version
Old 10-22-2008, 06:19 AM
Fast Freddy
Looks good so far! Hopefully they'll switch to a better grade plywood. Are you planning on fiberglassing the entire airplane or just the fuselage? Looking forward to the rest of your build!
Old 10-22-2008, 12:55 PM
siddus74
siddus74's Avatar
Freddy,
After the Cat and the Canadair I am definately going to glass and spray the entire hull (solartex the wings though I think) the thing is the plan calls for 3/16 balsa sheeting on the sides which is rediculously thick, I have used 1/8 but still think that is was a little over the top. Some of the rear curves were a pain to achieve even in 1/8th with out splitting, and wetting is a pain with the risk of warping.
The 4oz cloth and the wing skinning epoxy is so easy to put on with the small sponge rollers from fibretech and for such a small weight penalty the finish, logivity, additional strenght, puncture resistance and sound water proofing makes it in my eyes a no brainer. Film and water dont mix in my experoence, after a season the model looks tatty and when the film lifts you are inevitably looking at a recover [&o]
Old 10-24-2008, 01:52 PM
siddus74
siddus74's Avatar
Not managed to do a lot today - car had to go to the garage (bang goes the swap meet funds)
I braced the front as I saw fit and put 1/8 doublers against the 1/8 light play keel as it gives more suface to attach the planking too - I found this helped as I did this to the Canadair after the Cat hull planking was a nightmare (more glue on hands than on wood, planking springing off as well)
ID:	1058013   Click image for larger version
Old 10-24-2008, 06:31 PM
Rcpilot
My Feedback: (78)
Rcpilot's Avatar
ORIGINAL: Wayne22
My sentiments exactly.
Would be REALLY cool with 100" span and 60 - .75 size engines.
Old 10-25-2008, 06:04 AM
Fast Freddy
Siddus74
Planking with 3/16"? I bet that's a mistake, 3/32" should be plenty. How about 3/32" plywood, very strong! Fiberglass the entire hull with either epoxy or water based polyurethane and it should be pretty watertight. I used poly u on my last project, worked well, applied 1 coat every 3-4 hours for a total of 3 coats. West Marine epoxy seems harder though. Nice build so far!
You mentioned you built a Canadair and a Catalina. Were these kits? and if so, could you please list contact information. I'm always looking for flying boat designs / kits as 90% of my flying is off of water.
Old 10-25-2008, 06:06 AM
simhatus
Hi
I helped siddus74 put the fuslage together, as afore mentioned the formers where warped and it was all a sloppy fit also some of the slots for the keel wern't even in the middle.
should have used them as a guide to draw up a plan and make some acurate balsa ones, then used them on bonfire night to start the bonfire.
Simon
Old 10-25-2008, 06:09 AM
siddus74
siddus74's Avatar
The Catalina PBY2 was built from the RCM plan by Budd Chappel; the build log is on here as is the uild log for the R T Models Canadair which was a kit. have a search in this forum your find many pitures etc.
Old 10-25-2008, 06:24 AM
Fast Freddy
Thanks!
Old 10-25-2008, 01:01 PM
simhatus
hi
have now assisted in the assembly of the wing
The wood quality is just as hopeless as the fuslage.
also why is the last rib w18 flat bottomed when the rest are semi symetrical? , this would have resulted in built in washin.
we replaced the rather short dihedral brace (didn't even go past the first rib) with a much longer 1/16th ply one.
We also replaced the false leading edge and actual leading edge with a conventional single leading edge.
we now have the unlikely task of modifying a second wing to match overall unchuffed with the whole design.
Simon
ID:	1058568   Click image for larger version
ID:	1058569   Click image for larger version
Old 11-04-2008, 06:01 PM
siddus74
siddus74's Avatar
Done some more to the wing, kinda making it up as I go. The plan does not show a trailing edge of any description just full length ribs - I have put a small trailing edge on now, at least I will have some thing to glue the sheeting to now!. I dont get why people try and re-invent the wing . . .
Any way the wood is of the usual poor quality (shame on you SLEC) and much work has been done to ensure we at least end up with a wing that has no wash in.
Notice the inboard ribs have been out set around the engine nacel area, this is to take a 4oz tank - no brushless here!
ID:	1065606   Click image for larger version
ID:	1065607   Click image for larger version
Old 11-06-2008, 05:28 PM
siddus74
siddus74's Avatar
Bored with the wings so decided to have ago at planking the hull. The plan said to use 1/8 or 3mm - decided to give them the benifit of the doubt, by the time I got to the front things were getting difficult - I knew I should have done it with 3/32.
Do they ever build from there own plans?
With the front half done and alot of cyano on my fingers the back half was completed in half the time and have the effort using 3/32, plenty strong enough.
ID:	1066803   Click image for larger version
ID:	1066804   Click image for larger version
ID:	1066805   Click image for larger version
ID:	1066806   Click image for larger version
Old 11-08-2008, 10:51 AM
chinehamgeorge
chinehamgeorge's Avatar
Scotty
You're gonna spoil it by putting those big and ugly IC things in it, should have gone brushless, you could have got away with a nice big battery in the middle, could have done you a deal
Cheers n beers
George
www.4-Max.co.uk
Old 11-12-2008, 03:59 PM
siddus74
siddus74's Avatar
Managd to fine a couple of hours tonight, the wing tips have been bugging me due to the plan calling for blocks being glued on the end then carved and sanded, wasnt to keen on carring pointless weight and then trying to get them the same shape and curvature - opted for an improvised built up version (let the solartex make the shape then)
Not to hard just took a little thought . . . Now I can get on with some thing interesting like the engine nacels.
ID:	1070902   Click image for larger version
ID:	1070903   Click image for larger version
ID:	1070904   Click image for larger version
ID:	1070905   Click image for larger version
ID:	1070906   Click image for larger version
Old 11-13-2008, 05:58 PM
siddus74
siddus74's Avatar
Got another couple of hours in this evening . . . I cut the original firewall supports about to bring the firewall position back to the LE - this inturn ensures the prop driver is in the same position as if I had opted for a brushelss setup. Good thing was the original round light ply firewalls could be used on top of a proper 1/8 ply firewall so to keep the roundness in the nacels.
Used the pillar drill chuck to press the blind nuts into the ply, nice and square
Committed now with epoxy, IC it is then.
ID:	1071557   Click image for larger version
ID:	1071558   Click image for larger version
ID:	1071559   Click image for larger version
ID:	1071560   Click image for larger version
Old 11-14-2008, 03:38 AM
siddus74
siddus74's Avatar
ORIGINAL: Lake Flyer
I have just had ane email that confirms that the magazine article is in the Dec / Jan 2008 issue of RCME
[link=http://www.modelflying.co.uk/news/article/mps/uan/599/v/1/?source=weeklyemail&attr=news1]http://www.modelflying.co.uk/news/article/mps/uan/599/v/1/?source=weeklyemail&attr=news1[/link]
