Float dimensions
Hi. I wanna set up my kadet mark II on a single center float, with two wing tip floats. There are two things i need. I need plans for floats of all wood construction, and i need the dimensions for the big center float and the two wing tip floats. The dimensions of the Kadet Mark II are: Fuse Length- 44.25"
: Fuse width- 4" : Wingspan- 57.25" : Weight- 5-6 pounds (approx) |
Float dimensions
Here is a link to a calculator that will give you the float dimensions.
http://www.armoredplanet.com/hcfc/floats.html |
| All times are GMT -8. The time now is 11:16 AM. |
