RCU Forums
-   Seaplanes (https://www.rcuniverse.com/forum/seaplanes-176/)
-   -   Great planes float kit Alpha 40 (https://www.rcuniverse.com/forum/seaplanes-176/11165819-great-planes-float-kit-alpha-40-a.html)
Whats the rudder for 07-23-2012 08:33 AM
Good day,
I am trying to mount a set of great planes fiberglass floats on an alpha 40 and the nose sits too low. I believe I saw a similar post somewhere on this Site where someone modified the wires to give an appropriate incidence angle. I was wondering if anyone who has mounted these floats on a tri-gear aircraft could lend some advice?
Thanks<br type="_moz" />
chistech 07-23-2012 02:24 PM
RE: Great planes float kit Alpha 40
Take a few pictures of the floats and plane with the step in the correct location (+or- 1/2" from center cg). It will be easier for people to give you ideas. I assume you are trying to use the strut wires in the stock "cub" configuration.
