RE: post Cub, and other float plane pics
1 Attachment(s)
Sig 1/4 scale Super Cub in the bones. H9 floats, ASP 1.60. Should be finished this spring.
1 Attachment(s)
This is a pic of my 40% Cub on scale PK-2050 floats being water tested in the pool before the maiden, if all is good the floats will be painted after the maiden flight.
1 Attachment(s)
The floats have been painted and the cub has been re-rigged.
1 Attachment(s)
This is a pic of the super cub back on water. If you look closely you will see the cub is about to lift off and just the step is touching the water.
1 Attachment(s)
Hi Guy's her's mine a Senior Telemaster on 60 size Great Planes Floats Kit built,They work great in the snow!!!
1 Attachment(s)
Not a Cub.
Rather an experiement that did not work. I crashed the airplane before I was able to make the hull work as intended. |
1 Attachment(s)
My Hangar-9 "FrankenCub."
Had enough pieces parts of a H-9 1/4 scale cub, stripped all the yellow covering and put on orange and blue Solartex, then painted on orange and deep blue Rustoleum. Rib stitching and pinked corner reinforcements all over the airplane. Looks very neat. A DLE-30 in the business-end with a Dave Patrick Super Cub Cowl from Fiberglass Specialties. 3" tru-turn spinner cut/drilled for a Xoar 18X6 prop. Hangar-9 Cub floats. Mixture of JR-821 digital servos and Hi-Tec high-voltage, metal gear, ball bearing digital servos. Still have to install the ignition, voltage regulator and throttle servo, then final set-up on the floats. Spektrum DX-8 radio. |
1 Attachment(s)
A few pics of a 60% L-4 maidened in Florida last week. Bob and his son Matt are visiting in Floridagetting some big float planes ready for the Nall/12
| All times are GMT -8. The time now is 05:06 AM. |
