RCU Forums
-   Seaplanes (https://www.rcuniverse.com/forum/seaplanes-176/)
-   -   Seamaster lateral balance (https://www.rcuniverse.com/forum/seaplanes-176/2631001-seamaster-lateral-balance.html)
britbrat 02-07-2005 01:28 PM
Does anyone have a simple method for checking the lateral balance of a Seamaster?
MinnFlyer 02-07-2005 02:56 PM
RE: Seamaster lateral balance
Set it on a piece of 1/4" square stock right down the center.
If it falls to either side, add weight to the opposite wingtip.
jrf 02-07-2005 04:17 PM
Make sure the engine is not up against compression. Hold the airplane up by one prop blade and the very top of the stab. Add weight to the higher wingtip until in hangs level.
Jim
britbrat 02-09-2005 02:07 PM
Thanks, to both replies.
