RCU Forums
-   Seaplanes (https://www.rcuniverse.com/forum/seaplanes-176/)
-   -   Mildew (https://www.rcuniverse.com/forum/seaplanes-176/437362-mildew.html)
JimCasey 12-24-2002 09:44 PM
Mildew
Seems like every time I have to repair a seaplane, when I peek under the covering there's an infestation of mildew. Today, I opened up a previously undamaged wing that's only been on a seaplane for 2-3 weeks, and it's got a load of mildew in it.
What can I treat the balsa with before construction to prevent mildew? (It must not prevent the covering/glue from bonding to the balsa)
Steve Guinn 12-24-2002 10:22 PM
Mildew
Kilz prevents mildew but I don't Know if it is suitable for covering.
drlsgt7 12-24-2002 11:53 PM
Mildew
After i fly my sea plane i take the wing off and let totally dry. Have never had a mildew problem. Also after losing two planes in the lake i started taking the Batt. And RX out of the plastic bag and let dry. Havnt had a problem since.
Trombe 12-25-2002 01:47 AM
Mildew
You could coat the whole thing with epoxy (heehee) :)
tpstorey 12-29-2002 01:03 AM
Mildew
I've never had mildew but I've seen it on others. Before I cover something I plan on flying off the water, I spray the whole framework with a light coat of polyurethane (from a can). I wonder if that helps. Anyone know?
PeterC 01-05-2003 03:34 AM
Mildew
You might also try venting the whole structure as you build your next plane. I believe mildew starts from trapped moisture which can't evaporate thus creating an ideal environment for the mildew fungus to start growing. I also agree with tpstory that spraying the entire structure with polyurethane will help seal up the wood and help preserve the structure.
I always disassemble my planes so they can breath when I'm not using them. I'm sure boat builders, especially those in coastal areas have a few tricks to prevent this problem.
My current project is a twin engine, scaled-up Aqua-Star for two 25's. I hope to keep this plane for many years so preservation is a priority topic.
Lets keep this thread alive because I for one would also like to have a few tips on this matter.
Peter
