RCU Forums
-   Seaplanes (https://www.rcuniverse.com/forum/seaplanes-176/)
-   -   RC scratchbuilt Albatross in progress (https://www.rcuniverse.com/forum/seaplanes-176/5734956-rc-scratchbuilt-albatross-progress.html)
www.stef.com 04-18-2007 12:55 PM
Hi everyone. I'm scratch building a large brushless electric scale Albatross. I'm basing it off of stuff from the internet as well as an old monogram model I bought off Ebay. It will have a two piece wing, a video camera in the nose, and still camera in the aft belly. I though I would share the completed chassis and retract mechanism that I will build the fuselage around. The final wingspan will be 2.3 meters. You can see a video of it working at the following link. http://www.stef.com/Chassis.mov Now on to the wings!! (I tried to upload pictures here but I'm having problems)
[link]http://www.stef.com/Chassis.mov[/link]
cargo1 04-20-2007 08:00 AM
RE: RC scratchbuilt Albatross in progress
i'm glad to see that there are other people out there doing this kind of stuff. am trying myself to do what you have done, that is an awesome plane to myself to. as soon as the temp lets me out to my workshop i myself will be doing a dc3 settup. keep going!
Fast Freddy 04-21-2007 03:32 AM
[8D]Stef,
That is one awesome retract mechanism you've designed! Simply brilliant! Can't wait to see the rest of your progress!
www.stef.com 04-21-2007 09:24 AM
Thanks guys, I'll post more in a few weeks :) -stef
www.stef.com 06-26-2007 09:14 AM
Hi everyone, I've made a bunch of progress.
I'm very near completion of the basic construction and then I can move on to finish work.
So far everything you see weighs 5.9 lbs or 2700 grams - so I am l on my way to meeting my target weight between 7.8 and 10.4 lbs. or 3538 and 4717 grams
Once the entire model is sheeted with 1mm balsa, I will cover everything with 3/4 ounce fiberglass.
Thanks BigR for you advice on using an elevon mixer for my differential thrust, works perfectly!
I've uploaded another progress video here:
[link]http://www.stef.com/JuneProgress.mov[/link]
I hope you enjoy it and any comments, tips, or suggestions are greatly appreciated.
Again I try to upload pics here and I keep getting an error. I will try to figure out what is up and will post pics if possible.
:) -stef
www.stef.com 06-26-2007 09:30 AM
Okay, problem solved, here are some pics :) -stef
http://www.stef.com/Junepics/Construction.jpg
http://www.stef.com/Junepics/Wiring.jpg
http://www.stef.com/Junepics/Spinners.jpg
http://www.stef.com/Junepics/NavLights.jpg
http://www.stef.com/Junepics/DigitalCameraMount.jpg
http://www.stef.com/Junepics/Overview.jpg
http://www.stef.com/Junepics/GearDelayAdjust.jpg
will in the 985 06-26-2007 08:52 PM
nice. are you going to have plans available? because id be interested to build one. and those planes are awesome!
Bad_Daddy 06-26-2007 09:13 PM
WOW! Very impressive, and full of tremendous ideas! [8D]
www.stef.com 06-27-2007 02:08 AM
Thanks for the nice comments guys :) As for plans if enough people want them I would be happy to clean them up, write up some instructions, and make them available. How would you want them? As a pdf where you take it to a printer, or paper plans? I'm looking to have this thing flying early September so I could probably have plans dialed in and ready a month after that. :) -stef
LuftwaffeOberst 06-30-2007 04:59 PM
OMG Great work! Man I hope I get that creative one day. [sm=thumbs_up.gif]
Luftwaffe Oberst
Aero Modelers Club
AMA District II
Pulaski, NY
www.stef.com 07-06-2007 07:07 AM
I've got an identical thread over at RC groups. So this update is pretty much the same as I've posted there.
So I balanced and finished my spinners and props. I printed and sealed all my waterslide decals. I've decided to do a weathered look for the whole plane. I think it looks more real and is also a lot less work than trying to make every surface and detail perfect. Even though I have a lot of building left, I went ahead and took a few pieces all the way through the finish process so I could get an idea of how much time would be involved and how much work I was willing to do. My riveting was pretty shaky but I'm sure my technique will improve. I'm going for the 5 foot read anyway. I'm very proud of my grease trails though!
I hope you enjoy the pics -stef
http://www.stef.com/Albatrosspics/up...6_07/props.jpg
http://www.stef.com/Albatrosspics/up...6_07/layup.jpg
http://www.stef.com/Albatrosspics/up...07/process.jpg
http://www.stef.com/Albatrosspics/up...lsriveting.jpg
http://www.stef.com/Albatrosspics/up...stabilizer.jpg
g_boxwood 07-06-2007 11:43 AM
Your work is simply amazing!!! Keep it coming please!
www.stef.com 07-13-2007 12:27 PM
Thanks again for the nice comments! :)
I am progressing rapidly now, definitely kicking it into high gear to meet my self imposed deadline. I want to finish by August 20th because that is when I go off on a family vacation. First flights, with video of course, will be the weekend of September 15th/16th. I will post the video soon after that.
Cowlings:
I resumed work on the wings, this time with the top half of the engine cowlings. I had previously molded these forms wrapping saranwrap, then 6 oz glass, then more saranwrap around my wood form. They are featherweight at this point, and will have increased strength and stiffness when bonded to the wings, firewall, and bottom half. I roughed out the depressions for the exhaust stacks, and created fillets both inside and out with expoxy and microballoons. I will smooth the transistion later, and I will add the exhaust pipes at the very end.
Fuselage:
I finished sheeting the fuselage. Some parts went more smoothly then others. There are quite a few difficult transitions. I had to redo one section near the tail as I didn't correctly anticipate the way the tail's underside flows into the rear chines - I will update my plans accordingly should anyone want to build one of these for themselves. I then began to glass the fuselage with 2oz in the forward areas and 3/4 oz in the rear. I doubled up certain areas that I know I will be doing considerable sanding and thin filling.
Wheel wells:
After crossreferencing pictures of a real albatross, I decided to make my wheel wells more realisitic by adding the rounded section you can see in the pic, and narrowing my strut flaps to a more accurate dimension.
Front hatch:
I wanted to the nose section into a large removable hatch so I can easily service the still camera, the video camera, and the front landing gear mechanism should it need servicing. I knew I would end up with a thin fiberglass shell for the hatch so I did a sloppy basket weave-like layup of stringers. I used copius amounts of bondo to finish the form, drew and masked my hatch line, used furniture wax for mold release, applied the equivalent of 3 layers of 2 oz glass, and cut and released the part when cured. The remaining shell is very light and strong, and I plan to use a snap on tongue and groove type connection to the fuselage to ensure a watertight seal.
Until next time :) -stef
http://www.stef.com/Albatrosspics/up...13_07/cowl.jpg
http://www.stef.com/Albatrosspics/up...13_07/fuse.jpg
http://www.stef.com/Albatrosspics/up...13_07/gear.jpg
http://www.stef.com/Albatrosspics/up...3_07/hatch.jpg
red head 07-13-2007 06:28 PM
VERY NICE , brings back a lot of memories, I flew crew on one in the early 60's. ENJOY !!! RED
ByLoudDesign 07-26-2007 02:24 PM
Did a couple water landing, and takes off with jeto from Friench frigate Sholes; half way from Oahu, HI to Midway Island when I was stationed out there. The model looks great! Got plans started for a Donier DO-24, a real flying boat. It takes a long time to develope those plan, good luck!
alasdair 07-27-2007 03:47 AM
Hi,
Lovely job, a craftsman at work!
You mentioned glue dot rivets; are they applied individually or in rows through pierced tape (as in www.mickreevesmodels.co.uk )?
I once built a small electric powere Czech kit of the Albatros and found it floated a bit too nose down with their recommended flying CG, and so the nose tended to throw up water. It was OK once i got the nose up and the hull planing though. have you lengthened the nose at all to get more buoyancy up front?
Regards,
Alasdair
ArmedZagi 07-27-2007 09:23 PM
That is some of the best craftsmanship I have ever seen. The finish is amazing. Cant wait to see more. :)
www.stef.com 07-28-2007 07:32 AM
Thanks all for the wonderfull comments. You are too kind! The low res pics don't show just how "hand made" this thing is!!
Alasdair - to answer your question about the rivets I'm just doing them individually with a syringe. Once I got my rythem going it took about 20 minutes per stabilizer side.
Okay, more progress!!!!
Floats:
I ruined my first float mold by mixing to hot a batch of epoxy, which then rendered my mold release ineffective. I was left with my positive form, fused to the mold!!!! You can see in the upper left pic I thought I could ressurect the positive form and remold it, but I quickly realized this was futile. The following three pics show a new form, carved from EPS foam, then a layer of expoxy and bondo to smooth everything up, and the last pic shows a latex form in progress. I plan to split the latex mold in half, then apply several thin coats of epoxy and microballons to each half. Then when things are looking strong enough I will join the two halves add the tongue that will interface with the wing. The floats will be held in place by a magnet for simplicity, though the forces will be taken by rigid walls.
http://www.stef.com/Albatrosspics/up.../floatmold.jpg
Front gear:
I decide to paint up and weather some more parts that are done. In the top left pic you can see the front and rear rims for the main wheels (the more "dirty" rims are the inside ones)
and some pieces for the hydraulics and the front wheels. I then assembled the front gear and now its ready for installation. The long thin rod you see on the front gear shaft allows castering but brings the gear back in alignment so there are now problems with retraction, in theory..... :)
http://www.stef.com/Albatrosspics/up.../frontgear.jpg
Main cabin/hatch:
I decided to use a pushrod to create what I think will be a fairly watertight seal. I built the flange to support the female portion first, then added the rod, "dremeled" and sanded it open, then added the male portion, and a flange to support it. It mates quite nicely. Its not as "snapolicious" as I had hoped, so I will have to add a couple of simple clasps. The geometry is such though that with the wing in place, the hatch will not budge - so barring some major crash it should be easy to keep the hatch on and the water out.
http://www.stef.com/Albatrosspics/up...7_07/hatch.jpg
Wings:
I finished sheeting the bottoms of the wings and added the same unidirectional carbon reinforcement that I added to the top spars. I then mated the cowlings to each wing half.
http://www.stef.com/Albatrosspics/up...gsandcowls.jpg
Wings and fuselage transition:
Using a combination of 1mm balsa and EPS foam, I feathered the transitions between the fuselage and the wing profile. I will cover these transitions with 2 layers of 2oz and be sure to do all finish work with all the pieces assembled, to preserved the smooth transitions. I added a buffer of 1mm balsa, to create 1mm gaps between the hatch and fuselage, which I can then add squishy piping or something to create a water tight seal. I'm not too worried about a little bit of water getting in because the interior space is vast, and no electronics will be on the floor of the fuselage.
http://www.stef.com/Albatrosspics/up...ndfuselage.jpg
Cowl gear flaps:
To round out my landing gear setup I had to make one last set of flaps. The geometry on these cowl flaps is a nightmare, lots of funky angles, but everything seemed to work out in the end. I use a rubber band to link them to the gear, because when I take the wings off, these flaps stay with the cowlings. There is a small quicktime movie [link=http://www.stef.com/Albatrosspics/update 7_27_07/cowlgearflap.MOV]here[/link] that shows how the cowl gear flaps work with the rest of the gear flaps.
http://www.stef.com/Albatrosspics/up...wlgearflap.jpg
Minnreefer 07-28-2007 09:33 AM
Everything is VERY impressive. Please keep the pictures coming.
Jon
ArmedZagi 07-28-2007 10:26 AM
Looking good. What do you think your finished weight will be?
www.stef.com 07-28-2007 05:25 PM
ArmedZagi I'm shooting for a finished weight of 7.8 and 10.4 lbs. or 3538 and 4717 grams, and Alasdair I did not modify the nose for bouyancy. I kept it as scale as I can make it. In fact the only thing I've conciously modified on this plane is the airfoil/chord - but planform and wing area remain scale.
susquach 07-28-2007 06:53 PM
Stef, great looking project. Have you gleened any information regarding engine thrust lines/horizontal incidences?
www.stef.com 07-29-2007 08:09 AM
Sasquatch - nope, just pretty much eyeballing everything and using a bit of experience and intuition, then hoping for the best!!! I figure more suspense that way! I have 5 or six degrees of positive incedence between waterline and wing chord line, then I think about another 7-8 degrees based on pics between chord and thrust line. We shall see!! :) -stef
ccrebidoux 07-30-2007 11:47 AM
Stef,
Where's your "pull point" on that gear?? It almost looks like you'll need 2 servos to suck that gear up and put it down.
Chris
never mind, just watched the first video, HOLY CR*P!!!
www.stef.com 07-30-2007 12:01 PM
Hi Chris, this movie I had made should answer your question. I guess you could call is a pull pull system with just one servo doing everything :) -stef
[link=http://www.stef.com/Chassis.mov]Chassis movie[/link]
