RCU Forums
-   Seaplanes (https://www.rcuniverse.com/forum/seaplanes-176/)
-   -   seawind ep (https://www.rcuniverse.com/forum/seaplanes-176/6463978-seawind-ep.html)
adv777 10-08-2007 09:22 AM
seawind ep
How does it fly? I'm only 12 but i have been flyin for 3 years. Any suggestions?:D:)
MinnFlyer 10-08-2007 09:31 AM
RE: seawind ep
It flies very nicely. It's not hard to handle, nor does it have any bad habits.
I take that back, there is one slight bad habit to know about - If you're flying slow, and then zip the throttle to full, it will have a tendency to nose down due to the high thrust line of the motor. But it only happens when you're going slow and advance the throttle quickly. this can olny be a problem if you're low to the ground - like if you aboart a landing. Just be sure to add throttle gradually
