Electric to glow for E-flight DHC-2 Beaver
I would like some help/advice from someone who knows E power. I have a Saito .45 that I've been trying to find a plane for, and I've always wanted a Beaver on floats. I saw this Eflight Beaver, and it looks perfect for the .45, but since I am clueless on how much oomph the recomended power system for floats has, and how much weight the motor and batteries are, it's a little hard to figure whether the Saito will perform well. I looked at the manual online, and exept for the firewall, the plane looks like it should be plenty strong for the Saito.
My question to those in the know...Will this be a good match? I weighed the complete power system I would use (engine, prop, lines, tank and fuel) and it comes in at about 24 oz. total, 6 oz less without fuel. The Saito will turn a 12x5 MA 2 blade at 9700 rpm ready to fly on 15%. An 11x6 will probably turn about the same rpm. |
RE: Electric to glow for E-flight DHC-2 Beaver
rexracer: I cannot answer your questions about the comparison to e-power. But I can tell you from experience the Saito 45 will fly a Goldberg Anniversary Piper Cub and a Sig Rascal Forty.
I have seen the new E-Flite Beaver in person, and the Saito 45 will be more than enough power. |
Looks like I'm going to be doing an E to glow conversion:D
Kmot
What were your impressions upon seeing the Beaver in person? It looks great in the photos on E-Flite's site. Rexracer Keep us posted if you do indeed do this conversion. I would be interested in doing the same. Thanks. |
1 Attachment(s)
It looks better in person than in the online photos. It is very scale looking to me. It has the correct corrugated surfaces, awesome dummy radial engine, etc.
I'm going to be putting in an order for this soon. I hope it ships when they say it will. i will take lots of pics, and keep everyone posted.
I'm anxious to see what you do with this. :)
Me, too;)
I just got a reply to an e-mail I sent to horizon/e-flight about whether a Saito .45 would fly this plane on floats, and they said they don't recomend using glow on any of their E planes, due to them being built lighter and not having to deal with the vibration of glow engines.
Kmot, you've seen this thing in person.Any opinion on it being built too light for a glow engine? I know I'll have to reinforce some areas, the firewall especially, but I was hoping the bulk of the airframe would work as-is. Opinions, anyone? In particular, I didn't want to have to mess with the wing or do anything that involves removing covering. |
You got probably the stock factory response cuz they don't want return demands or money back for smashed products.
If you search around you will discover lots of people have installed glow engines in "electric only" airplane models. Usually all they do is fuel proof the firewall area and reinforce it a bit.
People have made glow models out of Guillow kits! You can't get any more flimsy than that! :p |
That's about what I figured. I was hopeing to get a little more usefull info than "we don't recomend that", like maybe area's to look out for. I'm still going to get the plane, and I'll take a look when it arrives, and go from there. Heck, as an electric it would need to stand up to vibration if the prop was even a little out of balance, and these little Saito 45's are pretty smooth from what I've seen so far. My LHS is getting some, so I'll probably get the plane there.
It is surpisingly a big airplane weighing over 4 pounds with a nice sized wing. You should do OK with this one.
rexracer: You can always mount the Saito on a vibration absorbing motor mount. :)
http://www3.towerhobbies.com/cgi-bin...?&I=LXD626&P=6 With the Sullivan mount, you bolt your beam mount to the Sullivan mount. Then you bolt your engine to the beam mount: http://www.sullivanproducts.com/Moto...sMainFrame.htm |
Can you blame them?[8D]
I'm actually new to seaplanes but I plan on buying this particular DHC-Beaver. I'm hoping this will be a good stater. My summer re-treat is on a lake In Wisc. I have the radio, I just have to buy all the requirements to fly this beast. I have been flying for just a couple of years, but I'm hoping I can handle this nice seaplane. Any help or modifications would be helpful. Are there any other seaplanes that are good for beginners, I'm sure there are plenty but I'm on a budget...like 500.00 or so.
thanks guys, Scott |
rexracer,
I put a o.s max .40 four stroke on mine and it works quite well, lots of power ! Only change I made was to add a plywood firewall and sheet the horizontal stab. Balanced out on the c.g. and didn't have to add any weight. Got quite a few flights on it and still goin strong. That thing isn't built any lighter than the glow models the put out. Go ahead and do it , it works fine. dan |
Sounds awesome Dan! Do you have any pictures or video you can post? :)
ahh, how refreshing to read a thread where the objetct is to convert from electric to glow - welcome back to correct way, real aeroplanes never flew on brushless motors, way to go Scott . . . I'll be following this one closel for sure.
That's good to hear. I have a "new" Saito .45 that I just broke in on the stand. I still don't have a plane yet, though.[&o]
Pics would be great, but I think the prop swing by a .40 four stroke (likely 11", 12" at most) will be too small to look good.
I also have a Saito .82 that could be used, if the airframe is up to it. I could swing a 14x6 with that.
Dfedorco, what prop are you using, and how fast is it spinning? You say it has lot's of power, so I'm trying to get an idea of what to expect from my .45
rexracer
I'm using a 11x6 for now and its going good. Gonna try some other sizes soon to see what I like best. As for the .82 idea ,, that is WAY over kill. It will require so much tail weight to balance it, and you will have to cut up so much of the cowl to make it fit. That size of an engine and prop will put so much torque on the plane that flying it may suck and it will be hard on the airframe. this airplane is a good for .32 to .40 size two stroke or equivelant four stroke. That o.s. .40 four stroke I have on it flies it nice with extra power to spare, but than again I'm old school and I dont hover and do 3d ! That saito .45 should be more than enough power,its not that big of a model and its pretty lite. I get the tail in the air ,hit the first notch of flaps and pull back and it leaps off the ground. |
DaveInLA
on prop size to make the plane look scale ,,,,,,,,what model airplane has a prop that is to scale ? |
| All times are GMT -8. The time now is 05:26 PM. |
