RCU Forums
-   Seaplanes (https://www.rcuniverse.com/forum/seaplanes-176/)
-   -   My First Float Plane (https://www.rcuniverse.com/forum/seaplanes-176/7213171-my-first-float-plane.html)
secret_squirrel 03-12-2008 11:22 AM
1 Attachment(s)
What does everyone think? Will She Fly? Just a little ego note, the pictures came out terrible. The third color is red not orange. Weighed in this am and 10 lbs. This has me a little nervous. Powered by a Super Tigre 75. May have to change the prop from a 12/8 to a 13/6. Pick away and let me know what I can do to make it better. Still have to paint and prime the floats.
Oh Yeah!! 03-12-2008 02:44 PM
RE: My First Float Plane
Looks Awesome Dan!!!
JimCasey 03-12-2008 07:08 PM
Looks good to me! There is no law that floats can't be natural balsa color. 'course if I paint mine they get painted "aluminum".
secret_squirrel 03-12-2008 07:43 PM
definitely going to paint them. Does anyone think 10 lbs is extremely heavy?
Thanks for all the responses
Dan
jrf 03-12-2008 08:07 PM
That would depend on the wing loading. As long as the wing loading is under 30 ounces per sq. ft. you should be ok. (25 would be nicer.) At 10 1/2 pounds (after you paint the floats) you wing area needs to be at least 806 sq. in. If it isn't, find a lighter airplane for those floats and a lighter set of floats for that airplane.
I don't think you will enjoy the way an ST 75 flies 10.5 pounds either.
Jim
mintie 03-13-2008 01:32 AM
secret squirrel....I am in the same positon as you ,just finishing off my first float plane....jrf makes a comment about your weight I have a piper tomahawk that is 9 lb with a wing loading of 33 oz per sq ft flying with a OS 46 engine.It flys very nicely and handles the wind fine.I used to build light but have since started to put a bit of weight into my models and they handle a lot better.I cant see why a ST 75 wont handle 10 lbs. A mate of mine flys a scale DC 3 with two 25s on and it weighs 10.5lb. he had an engine out and flew two complete circuits on one engine.It just proved to us at the strip that even a small amount of power when handled right will keep an aircraft flying.
water does seem to add a little extra drag...try it and see ......... Mintie.
