8ft beaver stab
does anyone have some close up pics of the horizontal stabilizer on the unionville 8ft beaver. i dont quite understand the "taper" on the bottom towards the tip :confused:
thanks very much |
8ft beaver stab
We had the same 'problem' and I ended up phoning Unionville and got the explanation, unfortunately I don't remember what it was. I seem to remember that you just followed what it said and it worked out.
Let me know if further thought doesn't solve it. Bart |
Beaver stab
You build the beaver stab upside down. The reason is, so that when you hinge the elev to it , all the hinges are along a straight line( so it doesn't bind )...The center part of the stab is around 3/4" and as you work out to the tip it becomes 3/8" there's your taper....I'll see if I can take some photos ,got to borrow a digi cam...
