RCU Forums
-   Seaplanes (https://www.rcuniverse.com/forum/seaplanes-176/)
-   -   first time float build (https://www.rcuniverse.com/forum/seaplanes-176/9499026-first-time-float-build.html)
maverick pro 02-12-2010 05:42 PM
1 Attachment(s)
ive just finished building my great planes 40 size floats for my g/p arf cub. these floats went togeather so fast and easy im hooked. this will be my first float plane and hope to do more. took 2 nights to build and i am not a builder. they will be finished in .75oz glass and painted.
mike
soarrich 02-12-2010 06:12 PM
RE: first time float build
Looks good.
maverick pro 02-12-2010 06:53 PM
thank you sir....they where a lot of fun to build.
mike
hugho 02-13-2010 12:48 AM
Hello Maverick,
You will enjoy building float planes very much.
I built my first one 15 years ago and and have done it ever since. Besides they're much more fun and easier to fly off the water,
See the previous message to 2d.
Good luck,
HughO
maverick pro 02-13-2010 02:34 AM
thanks hugo...ive never flown of water and always thought cubs looked good on floats. im going to do the floats with panel lines and rivets to scale them up a little bit. im aslo going to ad the cross bracing for the float wires to stiffen them up a bit and make them look a little better. just put them on for the photo to show pics.
thansk again guys...mike
42etus 02-13-2010 12:59 PM
Lookin' good, Mike
maverick pro 02-14-2010 12:20 AM
thank you sir
thanks...mike
cf-drg 02-14-2010 09:44 AM
ORIGINAL: maverick pro
mike
Well your a builder now...
I guess you'll have to venture into an aircraft kit next! You wont regret it.. Also make it a floatplane, you won't regret that either..
goirish 02-14-2010 09:48 AM
Congrats on building the floats. I use 1/2 oz. fiberglass with Polycrylic water base. Easy to clean up and flows on smooth. I take a old credit card and scrape off the excess. It is also not as heavy as epoxy. Just a though
maverick pro 02-14-2010 11:43 AM
hey guys...thanks. last night i used sig cloth with zap z-poxy finish resin. i do the same aply the resin then pull of the exces with a card let cure then sand the edges with 220. now i need to finish the bottom with a 1/4 coverlap. i will psot some more pics when the glassing is finished. the only all wood plane i have ever built is a roayl b-17. ive been building it from plans and a short lazer cut kit for the last year and itas about done.
thanks again guys....mike
