Neptune 40 final assy.
1 Attachment(s)
Have read thrust line on these planes s/b approx. 3 deg up & 3 deg right. Don't know about Ace Seamaster but on Neptune next to no adjustability here. Ques is this, what reference line is used when measuring t/l? With bottom of hull level current t/l is a little up; with wings and horiz stab level current t/l is slightly down. Any advice will be much appreciated.
RE: Neptune 40 final assy.
Anyone? Need some advice.
I did have the seamaster years ago, and built it just as the plans say. Now I do not know if the plans are the same or not.
1 Attachment(s)
well done guy, look really proyect ending, I´m finished my amphibian too, but nobody know about CG engine axis of pusher.
know how to take off this bird ??. best regard |
I might be having the same issue with my neptune. When I put it together, I simply mounted the engine to the firewall and away I went. Plane flys great!!! once its off the water..my question is how do you add the up up thrust? Ive heard adding washers to the motor mount will change the T/L. Maybe this is why mine takes forever to get into the are. It gets up onto step quick, but just gets pinned there for about 100 feet
| All times are GMT -8. The time now is 06:12 AM. |
