RC Drifting Discuss all aspects of rc drifting here!
Older electric 4 tec diff?
Old 10-12-2009 | 11:57 PM
goodoldlevi's Avatar
Default Older electric 4 tec diff?
Whats up I am new to drifting. I was given a older electric traxxas 4 tec and the front diff is bad! I have done some searching and have read of a few people using the nitro diffs.
My question is do you need the entire carrier and diff or will the diff fit in the stock electric carrier?
Old 10-13-2009 | 12:27 AM
Freequensee's Avatar
Default RE: Older electric 4 tec diff?
For the front, it depend on the diff case. If the case can hold a 10x15 bearing, you will be fine and all you will need will be the nitro diff and 2 10x15 bearings. I've had two E 4 Tecs and both had different front diff cases. Just check to see which one you have.
For the rear, you will need the tension cams that the nitro 4 Tec has. On ebay, there is a seller that sells the complete nitro diff with gears, bearings, and the cams. But that is the only other required part for the nitro diff swap.
Old 10-13-2009 | 11:29 AM
Thanks for the fast reply and great info. [sm=thumbup.gif]
