Simjet 2300 with xicoy fadec v6.0
Hi there,
we we have burnt the ecu while trying to connect a telemetry adapter and found a used fadec xicoy v 6.0 gas start.
Anyone flying this combo please help to get us the parameter for start and run.
thx in advance
cheers
Gordon
thx in advance
cheers
Gordon
NJ
Hi,
Here's the info I got from a friend.
Each engine is different but this should get you going.
Start menu:
Pump Start Point AUTO +2
Pump Start Ramp 006
Glowplug Power 1.8V (using 2 cell lipo)
Gas Start Adjust 59%
Low Batt Volts 7.2V
Starter ignition power 070
Starter ignition max rpm 5,000
Starter ignition min rpm 2,000
Pre-heat time 2.0 seconds (I think this one can be reduced)
Gas off RPM 13,000
Starter power at fuel ramp 065
RPM 100% starter power 23,000
RPM off starter 21,000
RPM reconnect 19,000
Start mode auto-gas
Run menu:
Full Power Speed 122,000
Idle Speed 30,000rpm
Stop Speed 20,000rpm
Start/min temp 100°C
Max Temperature 800°C
Acceleration delay 004
Deceleration delay 011
Stability delay 090
Pump Limit 1020
Let me know how you make out as I have to convert two 2300's as the original ECU's have gone bad.
Jon Van Skiver
Start menu:
Pump Start Ramp 006
Low Batt Volts 7.2V
Gas off RPM 13,000
Start mode auto-gas
Run menu:
Stability delay 090
Pump Limit 1020
Jon Van Skiver
