Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > SimJet Turbine Direct Support
 Bp 2197 turbine-oil for lubrication? >
SimJet Turbine Direct Support Direct support for SimJet Turbines provided here.
Old 12-18-2003, 08:28 AM
Default Bp 2197 turbine-oil for lubrication?
Hello guys
The Simjetmanual says that I should use Exxon 2380 or Aeroshell 500 OR 560 turbineoil.
I wonder if I can use Bp:s turbinoil 2197 instead.
On our MD-80 fleet we have change from Exxon 2380 to Bp 2197 oil.
I know that Bp 2197 have a higer temperature when the oil will oxidate.
Best regards Tomas Eklund
Old 12-18-2003, 08:47 AM
KevinM's Avatar
Default RE: Bp 2197 turbine-oil for lubrication?
Hi Thomas,
I'll see what I can find spec wise on the BP 2197. If it's a newer product then it may very well be useable, although strictly speaking you should adhere to what's recommended in the manual. (I know of several other types of turbine oil that aren't listed but work just fine...)
Old 12-20-2003, 02:30 PM
Hi Kevin
I looked at the oil-cans and I read out following information:
Bp 2380 meets : MIL-PRF-23699F-STD
NATO CODE 0-156
9150-01-476-1074
BP 2197 meets : MIL-PRF-23699F-HTS
NATO CODE 0-156/0-154
9150-01-439-0756
I hope that the information will help you to find out if I can use 2197oil.
Old 12-21-2003, 04:52 PM
KevinM's Avatar
Hi Thomas,
I found the same information from the respective product sheets. Other than the fact that the 2197 seems to ba a bit more viscous, I can't really see much difference either. Having said this, it would be unwise of me to endorse a product without the factory approving it. We will forward your question along to Lars at SimJet and see what he says...
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
