Propane regulator
My Feedback: (32)
Propane regulator
Kevin or Ed,
It's getting close to first startup time for my 2300.How many clicks open on your propane regulator is a good starting point.Also,I want to tell you how pleased I am with that UP3 valve you sold me.It works perfectly on my F-15.Thanks again for your help!![8D]
Erik
Erik
My Feedback: (7)
RE: Propane regulator
Erik,
I am sure Ed or Kevin will add to this but on my 2300 I started with three clicks. I had a couple of failed starts at 3 clicks due to the temp not getting to 100. Then I opened the valve to four clicks and have had at least 15 starts now without any problems.
Brian
Brian
ON, CANADA
Hi Guys,
I normally only need two clicks on the reg, although sometimes I'll go to a third click. If that doesn't provide enough flow, check that the restrictor on the propane solenoid is sufficiently open.
