SimJet Turbine Direct Support Direct support for SimJet Turbines provided here.
Starting Temp
Old 05-12-2004, 03:24 PM
My Feedback: (7)
BCoston's Avatar
Default Starting Temp
Kevin or Ed,
Lately I have not been getting a high enough temp on propane to open the fuel solenoid. I have the propane solenoid valve fully open and have been opening my GNM propane regulator 3 clicks as I have always done. Lately it has only been getting to 85 - 90 degrees. This weekend I am going to use power max and see if it will give me a higher temp.
Old 05-12-2004, 07:58 PM
KevinM's Avatar
Default RE: Starting Temp
Is your propane source running low? The switch-over temp on your 2300 is set to ~100C, so you shouldn't have any issues acheiving that with propane.
Another thing to check is that the thermocouple is fully inserted in the tail cone. (3/16" - 1/4")
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
