Projet for AES2300 or 2200Value
Hi there
Is it possible to use a Projet ECU for the Simjets? Just as an alternative to Simjet FADEC and Casper?
I must be Plug'n Play, but I see no reason why it shouldnt work, but you might...
ON, CANADA
RE: Projet for AES2300 or 2200Value
Hi Lars
It should be possible to use the Projet ECU with the SimJet turbines. Up till now, all they had was an optical rpm sensor, but it now looks like they have a hall effect rpm sensor. You would have to replace a the rpm board on you engine with the Projet board as the electronics are not compatible.
Good Luck.
Ed
Good Luck.
Ed
