Inner tailcone-Simjet 3000
Kerry, after 12 flights since my starter motor repair( which you kindly repaired) my inner tailcone broke off in flight causing a deadstick w/ a safe landing. Two of three screws spot welded broke. What do I need to send you to fix this. John Grigsby-DallasTX
RE: Inner tailcone-Simjet 3000
Hi John,
IF the Inner cone DID NOT make contcat with theTurbine wheel, you need only send me the nozzle and inner cone.
HOWEVER.. if ther was contcat with the Turbine wheel, you will need to send me your engine as the Turbine wheel is now out of balance.
Brg.
Thanks for your quick reply. We found a tiny nick on one of the blades so I'll return it to you as soon as possible-THANKS! JOHNG
