2300 dead...
I went to spark up my jet today and nothing. No led's on the switch plate, dead. There's power to the ECU and the switch is operating properly. Any idea why a Simjet 2300 would just stop working? There's no fuse in the ECU lol, so forget the obvious. It was fine when I put it away for the season last year. Anyone?<div id="myEventWatcherDiv" style="display:none;"></div>
RE: 2300 dead...
Hi
I have the same problem with my first Simjet, and it's has the old ECU in a green crimp plastic house. I never understand what was wrong with it. It was just dead one day. So I strongly recommend you to buy a newer ECU. Gaspars ECU work perfect with SimJet. If you need the settings for it, just let me know. // Jonas |
RE: 2300 dead...
I have one Nexus, 2 SimJet 3000 and one 2300. All convertet to Gaspar and kerostart. Work perfect!!
RE: 2300 dead...
Where would be the best place in North Ameriica to purchase a Gaspar ECU? Thanks!<div id="myEventWatcherDiv" style="display:none;"></div>
RE: 2300 dead...
I just put a Xicoy V10 ecu on a Simjet 2300. Works like a charm.....
I ordered direct for Xicoy..Fast delivery, excellent service... He has guidelines on his page for what you want to do. http://www.xicoy.com/upgrade.htm |
RE: 2300 dead...
So from what I read on the web site, the thermocoupler, gas valves and motor need to be changed as well? Think I'll bite the bullet and go with the V10. Would you share you parameters? Thanks!
ORIGINAL: Gary Arthur I just put a Xicoy V10 ecu on a Simjet 2300. Works like a charm..... I ordered direct for Xicoy..Fast delivery, excellent service... He has guidelines on his page for what you want to do. http://www.xicoy.com/upgrade.htm |
RE: 2300 dead...
OK, I ordered the V10 ECU with new valves, rpm sensor and thermocoupler. So do you think I need the 6v speed 400 motor, or will the old one work? Anyone want to share their parameter for the 2300? Thanks! I also ordered the Gyrobot 900 jet, so it will be exciting to see how the old DV8R handles with some new upgrades.
<div id="myEventWatcherDiv" style="display:none;"></div> |
RE: 2300 dead...
RE: 2300 dead...
ORIGINAL: shaunrbell OK, I ordered the V10 ECU with new valves, rpm sensor and thermocoupler. So do you think I need the 6v speed 400 motor, or will the old one work? Anyone want to share their parameter for the 2300? Thanks! I also ordered the Gyrobot 900 jet, so it will be exciting to see how the old DV8R handles with some new upgrades. <div id=''myEventWatcherDiv'' style=''display:none;''> </div> |
Does the valve and pump have to be changed, as the original ECU uses 11.1 V (3 cell) while GASPAR uses two cell, 7.4 V.
I changed the valve and kept the pump.
Here are my 2300 parameters using a AU-605 Xicoy ECU
Start menu: Pump Start Point AUTO +2 Pump Start Ramp 006 Glowplug Power 1.8V (using 2 cell lipo) Gas Start Adjust 59% Low Batt Volts 7.2V Starter ignition power 070 Starter ignition max rpm 5,000 Starter ignition min rpm 2,000 Pre-heat time 2.0 seconds (I think this one can be reduced) Gas off RPM 13,000 Starter power at fuel ramp 065 RPM 100% starter power 23,000 RPM off starter 21,000 RPM reconnect 19,000 Start mode auto-gas Run menu: Full Power Speed 122,000 Idle Speed 30,000rpm Stop Speed 20,000rpm Start/min temp 100°C Max Temperature 800°C Acceleration delay 004 Deceleration delay 011 Stability delay 090 Pump Limit 1020 |
Thank for the info. Is this the same for kero start? Did you change the starter motor or thermocouple?
Hi Edgar
Thanks for the info. Simjet never had a Kerostart. you have to change the thermocouple if using the Gaspar Ecu. you can use the starter and pump but have to change the connectors. |
