RCU Forums
-   SimJet Turbine Direct Support (https://www.rcuniverse.com/forum/simjet-turbine-direct-support-199/)
-   -   AMA Required Log & Simjets (https://www.rcuniverse.com/forum/simjet-turbine-direct-support-199/2207043-ama-required-log-simjets.html)
MLaCoste 09-27-2004 04:09 PM
Hi guys-
As I'm sure you're aware, those of us that are AMA waivered turbine pilots have to log our flights (as all should do anyway) to renew our waiver.
My question is this......... Unlike some of the other manufacturers, Simjets do not show high & average data during a run (EGT, Fuel Pump Voltage, Fail Safe, & RPM). Are there any plans in the semi-near future to incorporate this into the next ECU/ IRDT software update?
Thanks!
Mark LaCoste
Very Happy 2300AES Owner!!!
KevinM 09-28-2004 06:37 AM
RE: AMA Required Log & Simjets
Hi Mark,
I'll pass this along to Lars as a customer request and see what comes of it. While I can't promise anything, if you don't ask you certainly won't get!
