simjet3000
hi my simjet 3000 will not start ,it was fine for the 4or5 test run and only had 3 flights in the plane and the last one flamed out .the engine starts on gas then shuts down leaving a red light on ,when i do get it to run it run for a very sort time at idal them flames out with lots of smoke out the back
RE: simjet3000
Hello zx6rg2 Can you describe the fuel system you have. The error light your seeing indicates a possible problem with your fuel system. Sincerely, Ed ORIGINAL: zx6rg2 hi my simjet 3000 will not start ,it was fine for the 4or5 test run and only had 3 flights in the plane and the last one flamed out .the engine starts on gas then shuts down leaving a red light on ,when i do get it to run it run for a very sort time at idal them flames out with lots of smoke out the back |
RE: simjet3000
hi ed ,i have a coke bottle and a bvm uht
RE: simjet3000
Hi zx6rg2
Ok. What kind of pick-up are you using in your coke bottle? Also, have you checked the fuel filter to see if it is plugged? Ed |
RE: simjet3000
If you have clear festo tubing back by the engine, do you see air bubbles in it?
RE: simjet3000
hi i have the simjet filter with tygon pipe and no i dont see any bubbles
RE: simjet3000
zx6rg2 Can you PM me your phone number so that I can go through this with you on the phone? Also, what pump do you have? Thanks, Ed |
RE: simjet3000
hi ed i live in the uk my number is 01543878294 i am using the pump that came with the simjet thankyou for help
RE: simjet3000
hi ed i tryed it with the fuel line off when it fired on gas i had a small amount of fuel comming out then the starter just keeped running with the red light on
| All times are GMT -8. The time now is 03:39 PM. |
