System Upgrade
Hi guys.
I have this old version of Auto Start 2250 turbine. I was wondering if any of you would know how much is the cost to have it upgrade to the current full auto start system? I tried to call the Simjet service here in the states, but i can't seem to be able to catch anyone yet. Thanks. |
RE: System Upgrade
Don't know when you called by have no message from anyone on this subject or a phone message w/ contcat no. on this subject. Please try again.
We check our messages daily, M>F. Also, as posted on RCU, we have a new email address: [email protected]. or you can use support@ ussimjetllc.com. The cost to upgrade to the new ECU system is approx. $700. (ECU, Solenoids, RPM sensor, all cables + labor) Thank you. |
RE: System Upgrade
Thanks Kerry.
I had called long while back, but i didn't leave a message. Anyway, Do i have to send just the engine itself, or everything back to you? Also, i was wondering what would be the estimate of the turn around time for this type of work? Thanks again. Neil. |
RE: System Upgrade
Hi Neil,
We require that the entire system be returned as we wish to test run with all of your componenets including your battery to ensure proper operation. I'm very busy at present and the turn around time is expected to be 5 > 7 working days. Best Regards, |
RE: System Upgrade
Thanks Kerry.
I will pack those up and get them their way as soon as the other half approve it first. :) You guys know how it is. :) Neil. |
RE: System Upgrade
Hi Neil,,We sure do.
Best Regards. |
| All times are GMT -8. The time now is 08:19 PM. |
