View Full Version : Glow Engines
- 180x muffler question
- Carb Parts
- sign of overheat? help plz
- 91 4 stroke HELP
- Can't get a good idle 4 cycle
- Irvine .53 Break-in
- os 1.60, pumped.
- prop break-in?
- MDS .48 It runs...finally
- 46FX with Jett stream Muffler on Dazzler PROBLEMS
- Fox Eagle 60
- Identifing a carburetor
- Help!!-New Saito 72 destroying glowplugs...
- Magnum XLS .40A - Needle valve substitutes?
- Lets take a poll on the FX 91
- Don Harris
- Two good motors gone bad
- Saito 91 muffler header/manifold
- Irvine .53 wants to keep running
- Magnum Engine, about to buy one!
- oil content in glows??
- DC motor
- Value of a K & B 100 DF with a Dynamax fan.
- Vibration Dampening
- tuned pipe on .40 LA??
- Thunder Tiger .91 four stroke
- Engine Quits When Opening Throttle
- YS91FZ Manual
- Muffler coming loose on 4 stroke .61
- MDS .40 infinitely lean
- Cox TeeDee Question
- Four stroke that sputters. W'sup?!
- Proper Prop for OS 120 III Pumped?
- New Saito 100
- Irvine .46
- Saito 80 overhaul problems
- Ys-63fz
- My field is all mud. Advice needed on engine cleaning.
- Saito 72 smokes and drinks, other bad habits
- Fox 36RX - broke the HS needle - now what?
- SuperTigre G-51 Ringed Vs. OS FX.46
- Teflon pipe thread tape on four stroke muffler threads?
- OS 45 FSR needs rebuilt?
- Os 48 Four Stroke
- Father's day was good to me - OS 91 4 stroke
- Questions on OS Surpass 4 strokes
- OS 120 111 pumped
- Irvine .53 Break-in Questions
- Pre-Surpass??
- Best way to clean an engine?
- Do I have to have a radial?
- TT Pro 46 Fuel leakage problem
- Engine missing after roll
- Great Engine Test Stand
- Engine Set Up- on the ground/in the air
- just one guys observation
- Carburetor setup on 2-strokes
- irvine prop
- HPI Nitro MT Engine upgrade. What engine?
- Irvine .53 problem
- MDS 218 anybody used one?
- MECOA-GMS WARRANTY
- prop choices for a satio 91?
- OS 61RF-P Hatori Pipe
- offset wedge
- looking for info on saito FA-60T
- Magnum 52 or SuperTigre ?
- Tower .75 question
- Enya 50 CX ?
- Enya Web Site
- Irvine 53 two-stroke vs. TT 61 -- Is the power output comparable?
- YS 120's the difference ?
- Newbie to Test FIRST Glow Engine!
- To DarZeelon...
- Disappearing Engines
- OS Engine Repair by Hobby Services?
- Help: GMS .76 will not start!
- Question for JAKA..
- Saito, Another nipple blows.
- Moki 2.1: Tank Distance from Engine
- Engine Mount
- rossi 53 aero
- Mixtures on Enya35
- Saito maintenance oil
- How do you "Summerize" a YS 53?
- YS Pressurized Fuel System
- What engines do you offer
- Enya .15 III Cylinder Head
- O.s.36 Low Speed Idle ???
- Moki Motors for Less
- Where can I find a onboard starter for a G-38?
- Enya 50 CX Muffler Question
- Fai Engines
- how much static power does OS .25FX have?
- super tigre gs-45 prop
- OS 50SX won't run strong
- Tartan twin 77
- rich mid-range
- 4 strokes throwing props?
- castor oil in a 4 stroke satio?
- WEBRA engine - carburetor?
- Leaky front bearing. OS .46sf
- Selecting the correct prop for your .60 sport engine
- Os 46fx
- Spinner size?
- Evolution .46
- k&B do thay still make em
- need instructions for OS61sf Pumper
- O.S. .40 FSR piston ring
- Mds Engines
- Tuning OS1.40RX Low End
- Saito 91S and a pump
- TT-91 four cycle
- old K&B .61 NEEDLE
- 4 stroke engine for GP CAP 232 or Extra 300S
- Saito 56 help
- OS .46fx s stroke or OS FS.52s 4 stroke
- Tower .61 lean problem
- Loose Needle Valve
- OS40LA Question...
- Iron Bay Fuel Regulator
- Thimble Drone Experts, what is this??
- Rossi 45 Price
- engine suggestions
- St 90
- I need help from the veterans
- Gas
- My engine always dies in the air :(
- Enya 45 ring?
- How to side-mount Irvine 53 if the needel valve handle was broken?
- O.S. 91 FX Problems??????
- GMS 47 cylinder liner alignment
- Reverse Rotation on SAITOs OS's ???
- Magnum XLS .52
- OS 91 4 stroke What prop????
- How do I set valves on Saito?
- west eurotech .50t1
- ASP Super Series????
- Walbro carb not pumping?
- OS SF .46 abc pump hook up?
- GMS 47 Brake-in
- muffler just bolt onto engine? no gasket?
- to build or not to build
- YS 45 problem solved
- SAITO 150 or ENYA 155
- Two fuel tank setup??
- Who makes the spring powered starter?
- So what does determine engine size?
- ABC internal failure
- Os .46 SF
- OS 1.08 BX-1 FAILED???!!!! 3rd tank need help...
- New OS 25 FP, value?
- 4 stroke comparable to 46 2 stroke?
- spinner nut for Magnum .15
- Saito 91 GK HELP!
- Moki engine
- Tank Size
- Norvel A .25 BB How do I make it a screamer?
- GMS .40, can it get my mustang in the air
- OS-61FX* Break-in with tuned pipe or stock muffler?
- Plane for a Saito 90 - 3cyl. radial 4 stroke?
- Starting Problems
- Need some help with Magnum 52 fourstroke
- Starting a Pumped OS Engine
- Engine for a SIG SE
- Engine Options?? Help Please?
- OS 70 fs surpass need info
- Enya 120R GP Mid-range
- What fuel on a 4 stroke?
- Saito 180 muffler problem
- OS 40 LA, Drilling the air bleed hole
- K & B .61 prop???
- Help, I just bought a used engine. Am I OK?
- MOkI 210 Prop Hub
- Webra keeps getting better with age
- AP Yellowjacket .15
- Irvine 53
- Cox .049 engine help
- perry carb on asp 91 2 stroke
- I just got my 03 Fantom .15!!Pics!
- YS 140 Soft mounts
- OS 48 FS prop question
- OS .48 four stroke settings and fuel?
- sidewinder tank position
- K&B 61 Prop shaft size?
- need magnum/thunder tiger .25 needle valve
- os 120 fs non surpass
- How long does a piston/sleeve last?
- what props for a mvvs .49 & .77
- Most powerful 0.15?
- Enya 60 (7032) pressure
- Quiet props. . .
- Having a little trouble!!!!!!!!!
- what is Webra Bully??
- Looking for TT GP .07 manual
- 4 stroke engines and LT-25
- ys 45 problems
- Mounting ?
- Super Tiger 3000
- Saito CC breather?
- YS 140FZ & FZ Sport?
- Saito 180 sag
- Question about Engine/Fuel Tank Height
- enya 35 IIIBB
- New Royal 40
- Saito 1.80 SMOKE
- MARVEL air tool = NAPA air tool ????
- Mufflers :PLEASE DELET
- Tru Turn Adapter For Saito 72?
- Enya 60X III / Enya 60X II
- Is it possible to make an onboard starter for a .12 size engine????
- YS 140 Softmount & Mufflers ??
- new fuel engine compression less
- 4 stroke question
- Beginner problems with a GMS .25. Please Help.
- Supertigre 3000 Ring and Piston
- Will a perry pump work?
- ASP 15 Low speed tuning
- os.46fx with macs muffler?
- Saito 150 and three bladed prop size.
- Radial Engine Information
- quadra pieces
- Thunder Tiger GP 42 manual
- YOUR NEWEST PRO ET CONTRA: MAGNUM FS 80 vs OS 70 FS
- Irvine: Who produces them?
- Magnum 80 four stroke-crashed, dont run well
- RCS 1.40 mounting bolt?
- 16 OZ tank enough for a YS 120 AC??
- Engine for GP Ultimate? os61fx to much??
- ABC worn out-when?
- proper break in for zenoah g-62?
- mvvs engine
- AP .15 yellowjacket
- Magnum engine question
- Soft-Vibe
- On-Board Glow?
- Weight of a tower muffler
- Blue Star 15 Combat
- Enya 40X.....Got Pistons?
- 4 Stroke Power Question
- 80 4C muffler
- OS 1.60FX: Which Perry Pump?
- Saito repairs
- Enya 60 III Need a Muffler
- OS160 Quitting Problems
- Sig SE - low-cost engine?
- YS 60FR parts help!
- Enya 80 2 stroke
- What are the different reasons for engine to stop during flight?
- HELP--Where Can I Buy a YS 91?
