View Full Version : Glow Engines
- Muffler pressure and bubbles prob - beginner needs help
- Please show me some tach readings for OS 120 Surpass III
- Carb Problem with Super Custom 90
- Saito Muffler Question
- Veco / K&B .61 Prop Driver?
- Which Saito 4 stroke for Astro Hog
- Question on Soft Mounts
- gms 61,76 ring motors good bad
- Anyone running an MDS 1.48?
- How do you check your head clearance?
- Magnum .46 slow response
- Best .40-.46ish engine for the $
- Os 46 La Auto Revs
- OS FT-160 Problems
- Saito 180 Backfire
- Saito50
- Champion Glow Plugs
- .45 supertigre problem
- .40 OS LA problems
- S90 liner removal
- 40 La Neede Positon
- OS 40 FSR Gaskets
- Magnum 52FS fuel plumbing ???
- Best saito 100 price?
- After Market Products. Better? Worse?
- Battery charger
- Pump a Saito 100?
- need engine manuel info for MDS 40
- why full throttle on first run?
- Supertigre 3000 Prop Selection
- black oil
- Enya 35V
- The Rare RC Engine
- St G-75
- YS 91ST Heli engine (where to get w/ what $$$?)
- T-Maxx Engines
- MVVS .77 vs. Super Tiger .75
- Saito 56 help
- Os 91 Fs Pumped
- *Resolved (sort of)* Webra .32 - Strange...
- Problems w/Saito 100
- Os Fs-52s
- McCOy 35 questions.
- Thanks Everyone
- should i use a fuel pump or tweak the engine
- Tuned Pipe
- Tuned pipe standoff for profile fun-fly?
- saito .65 idle screw
- Old McCoy .35 RedHead
- Magnum 91 FS thrustwasher
- O.S. .40 Trouble
- How to get Aviation Fuel
- After Run Oil
- Newbie trying to run in SC 40A Mk II
- saito 72 & 6 oz tank
- GWS 1.20 opinions??? (Oooops I mean G"M"S 1.20)
- breaking in an OS 52
- Engines
- good .21's???
- Running an O.S. 25LA
- OS .91 FX and Tuned Pipe????
- Looking for SuperTiger .60 information
- YS 91AC Help
- enough power??
- Any air tool oil or just Marvel's stuff as after run oil?
- YS80 won't settle into idle
- Os Bgx 3500 Vs Moki 210
- where can i buy O.S?
- K&B Engine Parts
- engine starter
- Os 46 Fx
- MVVS - carb low speed needle keeps coming off
- enya 25ssbb s enya25ssbb-jb25z
- K&B .21 shaft not long enough for fan
- Saito Questions
- This is a test
- What brand fuel tank for a YS engine??
- Moki Muffler
- Engine screws and valves question.
- engins
- TT 46 Pro - WOW
- Anyone have a RCS 215 Radial gas engine???
- RCS 215 4-stroke Radial gas engine
- First impressions
- Mac's Products???
- Saito Muffler Installation Problem
- Servicing my OS .90FS
- More performance from a OS FP .40 ??
- Saito 72 & 80...Best prop?
- engine loading up
- Good Place To Buy A Saito
- YS 140 DZ Breakin
- Moki 1.35 not pulling fuel
- 3-blade prop
- Rossi 90...Help???
- Bad New Engine `Need HELP!!
- where to buy MOKI engines?
- tuned pipe on a moki?
- RCV Engine size request Poll
- Engine repairs, Saito .80, @ ST 3250
- Webra Speed .91 muffler?
- Enya 45 6001 Specs
- Saito 40
- Tower Hobbies .46 Muffler screws
- Enya 35V
- Old OS parts
- OS FS 120 Surpass
- 1.60FX/best prop size???
- G23 or G26 Zenoah - Radio Interference w/Engine
- Plug qiestion
- Magnum 61
- Porting a Saito 1.20
- Tt54s
- Glow Plug STARTER HELP! AA Battery..
- os or saito
- Leaking on OS 91 fx
- OS 91 FS - no manual
- Prop for Webra 120
- 1.55 -throttle lever
- Ys 91 ?
- Diesel Conversions/Cold Weather
- Data sheet for MDS 40
- Adjusting Saito 72 high speed needle
- Magnum 52 4strk
- New Saito .40A
- Rebuild Enya .40 SS?
- 4-stroke question
- Clutch shoe removal ?
- Engine Building Information
- Where to get exuast pieces for Saito
- Tuning Saito 1.80, how do I?
- Saito 120 mount, hard or soft?
- Moki 1.8 & OS 1.60 fuel economy?
- Tower Hobbies 75 Pitts Muffler
- Thunder Tiger .46 vs Irving .53
- traxxas 2.5 upgrades
- Rossi-45 Any Problems
- ST 2300 on FAI
- Equal length blades for prop balancing??
- Cline regulator: needle sensitivity...
- Rebuild Moki 1.8 info
- Prop Position vs RPM
- Moki 1.35 Problems--help
- Muffling a Saito 300
- YS 63 Muffler Options?
- Which one would you buy?
- Turbo plugs
- Diesel fuels.. anyone know anything about em?
- Engine Problem
- Ringed compression
- bme 55
- Breaking-in on Nitro?
- Moki 180
- Fuel Tanks
- Prop buzz
- Cleaning Valves on OS 70II 4-stroke
- OS 50SX Prop?
- Brat/Bluebird 25 Magazine review
- Norvel questions for Norvel Guys
- Are you supposed to balance a wood prop?
- Fuel line length from tank to carb?
- 8 bladed prop on a Rossi 61
- engine alignment
- Ys 120 Ac questions..a wee bit O help please
- You gotta read this thread!!
- Webra .50
- Help me crank this Saito 300
- First start!
- Inverted engines
- Moki 1.8 carburator wont close all the way.
- Saito 56 Breakin Question
- Which engine 91 2s or 100 4s
- On board glow driver recommendations?
- Tiger Shark .91 Engine
- Adding oil to fuel to make 20% oil content
- TT pro .61 HELP!
- 46 size Rear exhaust engine?
- HP 61 four stroke help
- Help with Magnum 30 4 stroke
- Dave Brown Vibra Damp Mount-Enya 1.55
- New to cowled engines-help
- 91 Surpass not drawing fuel
- O.S.61rf-p tuning
- OS CVA .15 vs Magnum or MECOA .15
- Saito 65, Help
- Perry pumping air!!!
- Carb. on TT .91 FS, Reversable?
- Header Tube Length for 4-Stroke
- Problems with my OS 40 LA??
- 4-Stroke HELP!!!
- os 40 la
- Saito .72 and Perry p30 Regulating Pump
- ThunderTiger Pro .120 Inquiry
- Irvine .53 baffle
- gms eengines
- Graphics for prospective owners
- Tiger Shark 52
- tiger pro .46
- OS 40 problems
- Prop Sizes on TT 91s Four Stroke?
- Sc91fs
- Flexible Exhaust Pipes?
- Overlean run, piston appearance, symptoms?
- Does R/C fuel go bad??
- Mvvs 2.15
- Anyone tried Erickson MCC engines?
- Y S 91 Fz
- Enya .45 T.V. Type
- Prop keeps coming off
- super tigre .61 help needed
- Enya 120 4-c Help Got help delete thanks
- Saito 150 Problem Please help
- Os .91 Fx
- Pitts style muffler?
- first 4 stroke engine
- tuneable pipe available..?
- High Dia., Low Pitch 4 Bladed Props?
- 120 4-C muffler ?????????delete Please
- DELETE
- OS 91SX Acro Sport
- OS-FS70S choke
- Test stand question
- Help me decide between OS 91FX and Satio 91SGK
- OS .91 FX
- irvine 53
- help needed selecting an engine
- Have done or Can Do ?
- full wing goldberg cub/saito 45 mk2?
- 4 stroke saito or OS
- ps?
- tt 46 pro
- ZDZ60? Won't start
- Onboard electric starters?
- YS .60 FR Helicopter Engine
- In A pinch
- Ys 63
- Engine Recomendation for 120 CAP232
- Kwik-Fill and Cline ?
- Best exhaust Webra 32
- Repairing stripped plug threads in a cylinder Head
- Magnum XL46
- Saito intake manifold extention
- Webra Speed 61 F
- Magnum 25 Xl Carb Adjustment
- Y.S. 45 header bolts-what thread???
- Enya 1.20R
- Diesel fuel
- Zenoah G26
- Moki 2.10 and Cline Regulator
- Identify / Value of OS FS120?
