View Full Version : Glow Engines
- OS 50 SX and Irvine 53
- power rating of MDS 1.48 Pro?
- Break-in procedure
- ST g51 spray adjust
- A Poor Man's Ultrathrust Muffler?
- 4 stoke lubrication
- OS 91 muffler problems
- magnum 91 4-stroke
- O.S 1.60 FX ??
- Prop Selection theory
- prop questions
- Saito .91 problems
- Help. O.S. 91FX In Cowl Muffler
- Chat Tonight
- Chat Tonight
- AP .09 Hornet Idle Question
- What Happened to My Bearings?
- Moki Spinner
- Saito Installation in Fly Baby
- On Board Glow Problem Help
- Saito 150 or gas?
- What fuel do you recomend for the Weston 50V1 Engine.
- (How to) Install Main Bearings?
- Help With Changing Bearings
- parts for old OS engines
- Engine
- Bore X Stroke & Port Timing
- cs engine
- saito run (manufature) #'s (saito gurus)
- Magnum, Thunder Tiger, or OS?
- Tuning pipe for best mid-range
- takeoff
- RCS 140/180 vs Saito 120/150 vs Ryobi 31cc
- engine been in storage for 15 yrs
- Searched and searched, but cannot find, needle valve adjustment?
- Remote needle valve or not on 46 2S
- OK engine gurus, help me get my TT GP-42 running right again!
- TTFS 91 Sags on GPGILES202 When Inverted?
- saito 180 prop nut
- Magnum FS 91 RFS
- Saito 100
- Cline regulator
- A YS question, let's see how good you are?
- Does Hot and Humid affect engine
- help please! Thunder Tiger 54 carb problems
- YS 140DZ vs. 140L
- Saito 56 vs YS 63 opinions please.
- Fuel for Irvine .53
- OS or ST 91 Davis Diesel Conversion
- Magnum FS fuel
- 3 or 4 blade prop ??
- I have an old OS max .10
- OS 40 max-h engine
- Engine Thrust Measurment
- Help - OS FS-52 Idle Problem
- Any thoughts on the os 120 four stroke?
- Need a muffler end piece for my Enya 120
- OS Muffler help
- My FAVORITE YS isn't running right
- Irvine or Enya?
- FUEL FLOW PROBLEM? Please Help
- Rossi Vs Webra ??
- Rossi 45 With Mini Pipe Vs. Webra Speed 50
- after run oils
- How to clean Engines
- Fuel Efficiency?
- smoke fluid
- Computer controled engines
- Best Prop Choice for this Engine and Plane !? ...
- engines died just after take off
- saito vs fuel
- Magnum 1.6 twin FS quits and throws prop in mid air
- Saito FA-80 out of time ....HELP !
- How do Saito Engines do that?
- engine bogging on high speed
- Switched to wildcat 20/18, now the oily exhaust is darker brown?
- NEED TO KNOW ABOUT O S 240 4stroke
- cooler running engine ???
- Rossi 60
- Best 32-37 sized engine?
- OS 50sx-h will not idle
- Magnum 1.80 Question
- Fox 40 mufler
- YS 120NC has varying RPM's while flying!
- 20-30 yo os stuck carb. How to free it up?
- Saito 80 and 150 backfire problem.
- Quieting a MOKI 1.35
- Saito .56?
- ASP 91 prop ?
- stripped threads
- OS FSR 61 carb restrictor?
- Muffler extension on a stock OS 46FX
- Best Glow Plug for Saito Engines
- Baffle in Irvine .53
- Siedel Radial engines
- Est. rpm using load figures? Is there a formula?
- OS .91 II 4/ cyc w/pump
- Hatori pipe help!!!!!
- webra 32 prop
- Os 1.60 FX-FI
- Which O.S. engine is this???
- MPI Spinner Question
- Adjusting Saito Valves?
- Any substitution for silicone header coupler tube.
- engine
- Kavan 50
- Ohlsson 23 engine
- Enya 45X T.V. AL-CHROME any clue????
- Rossi .45 2000
- priming of carb
- matching engine to Midwest AT6
- YS FZ 91 fuel
- looking into a T/T 60
- Ys 91ac
- engine mount distance on gb ultimate
- APC hubs are too thick to use with most spinners?
- Where to find dyno results?
- Problems With OS 120 III with Pump
- What size mouse can to use on a pipe for a OS 91fx??
- electronic throttle syncronizer for twin
- New .63 YS.
- TT 120--Low Compression?
- Third time is a charm
- Breakin in
- Adjusting O.S. 61 Pump
- Need to make a home-made engine block gasket.
- Cooling a Pusher?
- Cox reed valve engines
- starting engine in mid-air
- Which prop reamer for Saito .72??
- Saito .65 Muffler
- OS 1.20 Surpass III with pump will work inverted?
- 4 stroke engine turnning propeller backwards
- 8 year old engine problem
- Enya 90-4C valve timing
- Exhaust Clearance :) for Saito :)
- What prop for os 160 FX??
- My Saito 72 is sooooo sweet.
- 40 Engine choice for speed
- Best engine for Ducted Fan application?
- quite muffler
- Lots of black stuff coming out of my TT GP-42's exhaust is this normal?
- OS 46 fx side mounted dies .....
- 91 Surpass sputtering in dives ???
- How can you tell for sure if your engine is fully broken in?
- OS 61 FSR carb help needed
- YS 120AC Fuel drip????
- Funny Noise When Prop Rotated
- YS Engines and 20/20 Fuel
- Tuning 4c
- Q400 vs G38
- Magnum XL-52RFS 4-Stroke
- Perry Pump Question
- Fuel lines/vent
- Where to Buy Ball Bearings
- Fuel for 4 stroke
- Trying to start 2 old engine, Need help
- need thundertiger F91S parts
- Changing head on an OS .91Surpass
- Saito ???? Ys 63
- Need help changing head on an OS .91 4-stroke
- YS 91 AC Surging in the Air
- saito 100 low speed needle
- AP Yellow Jacket .15 - Reviews, Comments?
- MFG RPM/hp specs?
- K&B 20 Sportster, muffler?
- 4 cycle vs 2 cycle vibration
- Flushing dirt from an engine
- OS50 sneezes
- Hot Spinner?????
- Zdz 40
- Zdz 40
- Please DELETE
- Webra 120 fuel draw issue
- OS 91 FX: carb settings
- Saito 80 Timing Gear Assembly
- Irvine .72 Prop??
- Waaahooo! Just got a OS 32 SX. What prop/rpm are you getting?
- Newbie question on TT .46 Pro packaging
- YS63 FZ....What Speed on Ground?
- Saito 180 with 18x6?
- Magnum Pro 28
- Gaskets
- Bad OS LA40
- Saito FA-.50 re-assembly
- Looking for a pitts type of muffler for a .91
- looking for a smoke muffler
- ST G90 overheating
- WHat is the size of the thread?
- YS .63 overkill for Sig SE?
- YS Si rubber valves
- Tuned pipe questions.
- Complete carb for Thunder Tiger 46pro
- Info Needed On Royal glow engine
- TT engines
- Mvvs 3.5 (.21)
- Fourstroke virgin.
- Stripped cyl. head threads on a OS 4-stroke
- glow plugs OS vs K&B
- Controlline to R/C conversion
- .40 LA average life span.
- Picco engine question
- Poll: Do You or Don't You Use Afterrun Oil?
- Webra 120,145 Aero X
- How to best adjust the air bleed screw?
- Engine problems/please help.
- Need advice for 1st 4 stroke.
- 3 Blade Prop on OS91 FX
- Over-propped?
- Who has best prices on glow plugs?
- saito 120 or 150 for goldberg ultimate
- Valve Adjustment
- need info on ross 60 twin
- 10-15 size engine
- Greatplanes Giles 202 Engine
- Engine questions need answered
- What solvent does everyone use to tear down and clean their engine?
- Enya 60 mixture question
- Webra Speed .50 - Any Good?
- saito 120
- Saito 180 run pressure from crankcase
- Magnum .91 FS versus the rest
- Irvine53/GMS47
- RCV Engines
- OS LA46 Idle problem
- Diesel Conversion, OS 40 LA
- Cleaning Old Glow Plugs
- Old Glow Plugs
- What plugs are you using for your 46 sized 2 stroke?
- Tiger Shark pitts muffer on my TT Pro-46
- Comparable engines to a US-41??
- Good prices on glow plugs ?
- Irvine Muffler choices
- Saito 100 help??????????
- cold weather running
- Best Glow plugs for K&B Motor?
- MVVS 1.6 Experience Update
- ladyflyer, help!!
- YS .63
- Tiger Shark Engines
- Battery Power For Glow?
- YS .63 breaking in
- saito 180 popping the vent line off the muff
- Glow Plug For Irvine .53?
- Breaking in a Saito 72 ( after the first 10 minutes)
- ASP 1.08 - can't get it started
- Ys 140l
- in-flight mixture for YS45?
- OS/TT .46 with Ultrathrust Muffler?
- Need help with YS 91AC
