View Full Version : Glow Engines
- OS 91 low end needle setting??
- Saito 45 Mk II
- Enya 60 X, need help!
- Moki 1.35 questions
- Magnum 120AR & Global Hobby Dist.(Good experience)
- 3 Blade Prop for TT46 PRO
- Need help: How do you remove a broken screw from a muffler?
- Hatori - OS.32?
- Irvine .53 - What's your RPM and Prop?
- Need help OS 46 FX bearing replace
- Please need help , Magnum XL .91 wont go higher than idle
- Os 70 Ii
- no pumps required
- OS 40FX and after-run oil
- Os160 Fx
- k&b 7.5 ducted fan motor
- Magnum 4-Stroke Specs
- how to mix castor?????
- Glow Plug A3 / #8
- Magnum XL53A Problem
- I need help with a muffler problem.
- Disadvantages to "pitts" mufflers?
- st g90 mufflers and props
- Os 160 Fx
- Need help with Webra Speed 40 - not end play but similar.
- saito 91 vs saito 100
- Saito 180
- MVVS 45/49 or the OS 46FX?
- Webra 10cc(60) black head
- 4C crankcase vent creates a mess
- OS LA40 Piston and Cylinder Gone
- Saito FA-100 Idle w/o Glow Starter ???
- OS 120 III with purmp - How to adjust idle mixture
- Pitts style muffler for TF Corsair 60
- Idle behaviour on OS.46FXH
- Blue loctite build up
- carb for picco .80
- Prop for a GMS .76?
- Macs Muffler and .46 Engines
- Break-in Question
- Breaking in an engine
- 4c fuel
- what fuel tank suitable for YS?
- Smoke muffler for OS 91 Four stroke
- Pitts muffler for .91 MVVS
- MDS 68 pro
- quadra 35 HELP
- Is After-Run Oil Necessary?
- why are OS Type F glow plugs so expensive?
- How turbines work
- most powerful .20???
- Saito 100
- Glow plugs
- Best engine for big Balsa Nova
- can 4 strock run clockwise?
- Thunder Tiger parts
- New Saito 100 With Rusty Bearings???
- Cline Regulator
- Super Tigre 75 needs tuning
- fox 46 abc
- Saito 56 Needs Repair-where Do I Send It???
- Can you identify this old engine
- Saito 180 to gas!
- Killer deal on Magnum XLS-46
- 91 FX - Best Muffler?
- RCV Engines need input
- Dynathrust props ?
- engine welding
- Thank-you
- Muffler Extension
- os 48 FS tunning/mixture
- Need Parts For Enya 120R (help!!)
- Engine for GP extra 300s
- Enya .80 Theory
- LOOKING FOR ENGINE PARTS FOR O.P.S or PICCO
- 3 Blade Prop for Saito 180?
- YS 63
- Are used engines worth the risk?
- OS 70FS timing
- RCV Engines
- 46 FX quitting on nose up.
- GP P-51 arf + saito .91 (prop ?)
- Oh, oh... I think my shaft has bent...
- Homelite string trimmer conversion
- glo engine question
- combine
- Fuel Dot Installation
- Who's got the most hours on a glow engine ?
- Dubro Kwik-Fill Fuel Valve??
- Perry Pump vs Muffler Pressure
- 91 four stroke or 61 two stroke
- Please Help - Reassembling 46 FX...
- ys 120 fz
- ASP and Magnum. Same engine?
- Os .91 Fx
- Crockpot/antifreeze engine cleaning
- Saito Pressure nipple "Pain"
- MDS .78 prop question
- Prop sugestions for Irvine .53
- Tap or use nut on engine mount?
- Webra .32 ?
- Pitts muffler on OS 91 FX
- Irvin .53's Sold DIRT CHEAP!!!
- Magnum 46XL Tip
- Mousse Can Pipes?
- Fuel free engine storage
- OS FS-60 Exposed Rocker NIB Value??
- ?saito 91 rpm???
- Magnum Muffler Screws ???
- brand new but older webra 40
- Crockpot cleaning
- mvvs 91
- Remote Glow drivers
- TT .54 four stroke adjustment info
- Would too much after-run do this?
- GMS .76 Prop
- st3000
- Break In ABC Engine
- suggested props
- Best FS 91 engine
- what does this do?
- YS 91 AC midrange
- plans for engine test stand
- bubbles in fuel line question
- Mds .58
- Whatcha flying w/ your YS 63
- Tuning a Saito .72
- Is this normal?
- hi i am a newbei have some Q on 2 stroke engine.
- Has anyone done this?
- OS CV troubles
- Can I use Coolpower 15% (heli, synthetic oil) with OS 25FP?
- Which Prop for Saito 100
- News helicopter Power - Os MAX-70SZ-H RING
- Question on US 41
- experience of Chief Aircraft?
- Os 50 30%& CY MP
- Saito .91 idle problem
- os 160 prop size needed
- Thunder tiger ????
- Bad day for engines. Magnum and ASP
- New Engines from OS
- Old OS and Enya Engines
- another ys91fz exhaust question.
- Anyone know the relationship between displacement vs mousse can volume? Engine Gurus
- Fuel line pinching
- Which Way? Up...Down....or horizontal.
- Balancing Props - What A Mess!
- Are ASP engines still available?
- Muffler Advice Needed
- Are the budget engines any good?
- HP 1.20 twin
- Question on an engine...
- Don Harris Smoke Pumps
- Tip of the week -- 3 and 4 blade props
- OS .15 LA, What can I expect?
- Tough one ?
- Fuel tank fill setup for YS63FZ
- OS 91FX & Ultrathrust
- engine mount, which one??
- Need Help, mounting MDS 1.48 upside down?
- props for norvel 061
- Cox Queen bee 074
- Simple onboard glow driver
- Greatplanes 1/4 extra 300s Arf
- How do you increase compression on a 2 stroke?
- Optical Tach? preferences?
- Soft Mounts - opinions please
- Which engine for my Uproar 40?
- Gms Engines Any Good?
- K&B61 for a TF P51-B?...
- Irvine 72 Problem
- 4 Stroke vs 2 Stroke
- MVVS or Rossi? Most powerful .60 sized 2-strokes?
- Some Webra help please
- OS 1.08 Inverted.
- Mvvs.49 Or An Os 50sx
- Os 61 Sf
- Best fuel tanks?
- rossi engines
- Ringed pros and cons?
- Mac Minarelli AVIOmac 85 Twin
- Max mufflers
- Power House 53
- Morris Power House 53
- TT Pro .36 mounting dimensions?
- Shaft Movement On Saito 100, Should This Happen???
- GUNSHIPGUNNER, Please post info on porting, etc
- Os 70 Surpassii, Problems Running??
- OS 50SX first flight (WOW)
- St G.90 w/Perry carb
- Irvine .53
- Porting 2 Stroke
- Things are a little better
- other options?
- 30% Nitro Blues
- 20+ y/o OS Max-s 35
- Anyone seen a pipe like this?
- YS 91AC question
- 46FX Quiting?
- OS 70 muffler question
- BIG bore VS long STROKE
- Will my Tower Power STarter 12V Deluxe start a .91 fourstroker?
- OS91fx prop for 3D
- Good? Bad? Tower Hobbies .46 Ball Bearing
- 2-Stroke vs. 4-Stroke
- Can you use a car motor for a plane?
- perry carb on a 90 asp
- Radial vs. Regualar
- enya vs gms vs mds
- YS120 4 stroke need owners ins manual
- MVVS .49 Question
- Need Exploded View for O.S. FS-90
- K&B 65 Sportster?
- throttle arm position on OS 70 surpass question...
- new saito engine
- Glow Plug after every flight
- Irvine 61
- 2-stroke carbs
- OS FP Substitute?
- Tt Gp 25
- coop
- Saito 56 rebuilt
- Enya 60 4st Muffler-Where??
- Moki 1.80 Glow vs. Diesel ??
- YS or Saito or OS
- Magnum & Thunder Tiger 4 strokes?
- Saito 100 or 120 on a .60 warbird?
- Prop for MVVS .26 Combat Wombat
- Engine recommendations?
- OS 91 FX or something else?
- Where is the best place to buy a Kavan Starter?
- engine choice
- MDS48pro aircraft engine
- Here it is my new 140DZ !!! - Pics
- What size battery for onbd glo saito 3 cyl
- Anyone here bought an OS .15 CV-A?
- Baffle Question
- Mvvs Twin to E540
- OS 61 SF problem
- 4 Star Power
- Muffler
- Saito 180 Cline regulator or not
- Muffler question.
- Saito .91
- Anyone tried similar installation?
- 3 bladed prop on mag 52
- Dark Exaust oil FX46
- YS 91 leaking fuel from the Carb
- Os1.40rx/fi...wow!!!
